ILS Brightness Issues??
no, it doesn't. The adjustment is just for the height, there's another adjustment screw for the spread. The auto high beam sensors are on the windshield and just decides whether the high beams are supposed to be activated or not. The adjustment screw is for the headlight housing, just for a starting point or reference. So, the internal "micro" adjustments are still done inside the assembly, like when you turn the steering wheel, inclines on the road and such.
I've always found MB factory settings to be too conservative. So far, i have adjusted my previous w204 with bi-xenons and my last c207, which also had the ILS headlights. Now, this on my w205. Its an easy fix so i really don't mind.
BMW e89 Z4 sDrive 35i & MB S205 C200 AMG Premium Plus
This is the adjustment screw for the height.
This is the adjustment screw for the spread.
The adjustments that we're making is basically a reference point at which these "gaps" (as you would call them) start.
When you turn the wheel left or right the light follows. And when you're driving and the road dips or you have a heavy load the "intelligent" light system adjusts the height to compensate for road conditions and vehicle load to avoid glare to oncoming vehicles. All of these light dazzle has to start somewhere. This is what we're adjusting. Some people like me, find the start or reference point too low. So, we fool the system by adjusting these screws. The functions remain the same.
2008 ML 320 CDI (07-21-2024)
Our cars just turn the high beams on and off according to surroundings.
#32
Adjusting these ILS screws don't need any programming?
Yes, i know what you're talking about. It's what i have as well.
