How to reset the Service Indicator
Hey everyone, just changed the oil in my C400. Does anyone know how to reset the service/oil indicator??
Thanks in advance |
By the way, I've done a search and found the following thread. It only unlocks additional information such as oil temp, but does NOT show how you actually reset the service...
https://mbworld.org/forums/c-class-w...nge-reset.html |
https://cimg5.ibsrv.net/gimg/www.mbw...0f9918cfa5.jpg
Originally Posted by marsfire
(Post 6560500)
Thanks in advance Sit in the car and close the door. Turn the ignition to position 1. Get the instrument cluster to the screen where the odometer is displayed. Press the left button once to highlight "trip". Press and hold the "accept call" button. While holding the "accept call" button press and hold the "OK" button. After several seconds the service menu should come up. Scroll to Assyst. At this point it should be self explanatory... full service, yes, confirm... Back out or cycle the ignition to exit the service menu use for w204 and w205 also apply keyless entry model hope it helps . |
Yep, I can confirm, I have done the reset
thanks, I can confirm that this worked as well!
To clarify, the "left button" that you reference is the "home" button with the picture of the little house on it. |
(Post 6635332)
Originally Posted by huyuci
(Post 6694025)
Hmm. This is really weird. I tried multiple times, with key in both positions and when I pressed "OK", it just went into trip and show the mileage. Has anyone else tried this? Does this work with every w205?
see video: |
Here is a little more detailed explanation. With keyless ignition just push the start button twice with your foot off the brake.
http://oilreset.com/2015-mercedes-c-...nterval-reset/ |
Hey everyone, just changed the oil in my GLC 300 2016 Does anyone know how to reset the service/oil indicator??
Thanks in advance |
Originally Posted by Gigi Nicolae
(Post 7094172)
Thanks in advance |
Just follow the steps in this link.
https://redirect.viglink.com/?format...erval-reset%2F |
I was about to change brake pad with my C250 W205 from Germany
The instrument menu for Reset somehow different 1. Set key to position 1 (one detent to clockwise) check display in Trip/odometer x00km/xx000 2. Press Call (phone call) button and hold 3. After one second, followed by Cancell call (phone end) button and hold 4. After another second OK button that will display service menu, As I wanted to reset the electronic brake to change the brakepad, it said, the brake reset does not meet the condition ? any other input appreciated |
When you reset the service indicator let's say for service A does it jump automatically to countdown for Service B?
P.S. I want to reset days, bud I don't want to mess up with Service A/B countdowns... I all I need is that next service will be with 365 days and not 180 what it currently shows |
2018 c43
Does anyone have the instructions to reset on a c43?
How do you reset a 2019?
the car has a scroll(touch control) button but no OK button. |
1 Attachment(s)
Originally Posted by petaling
(Post 7808368)
from step 4 do you choose the Assyst Plus menu?
While playing with the buttons I can access the Assist Plus menu in mine(not following your steps) but since my car is only one month new, it says no service required or something like that. |
(Post 7848839)
What about only resetting one element of servicing?
For example, if I change my brake fluid and I just want to reset "Service 4" (brake fluid) without resetting the oil or other items, can this be done? |
Works all the time !
