prrsonal poi's
C class w205 amg line
prrsonal poi's
I have tried to install speed camera poi's from PocketGPSWorld.com via sd card on my w205 with command online. However when I insert the sd card in the slot on the car I get a message asking to insert sd card, the card is formatted 4o Fat 32. The instructions on PocketGPSWorld.com says command NTG 4.5, I believe the 2015 W205 command is NTG 5.0. Can anyone advise.
2015 C220 AMG Line Bluetech.
Couple of things to check:
I know it sounds daft, but you are 100% certain it is an SDHC card and not, for instance, an MMC Card you have re-cycled?
I don't know about SDXC…?
What capacity card is it? Again, relating to SDXC.
Have you put the POIs into the recommended Directory? I'm not at home, so can't confirm the Directory ID, but if they aren't there, then COMAND won't find them.
Hi again,
Thanks for your help, however no joy. I have the directory as stated in pocketworld gps instructions ie PersonalPOI, But the command doesn't recognise any card inserted, it is greyed out on the screen.
Regards
John
Regards
John
I have now tried a different sd card but no good, however mp3 music does play.
I guess this is the end of the road.
Thanks gor all your help.
Regards
John
Regards
John
Hi again,
I think that I
I have cracked it , I tried with the directory as " Personal POIs" this opened the 3 dialogue boxes which asked if you want to display on map with audible alert or without.
Best regards
John
I think that I
Best regards
John
