Auto Brake Hold
I've had a 2015 C300 Sport for a few months now and have never been able to get the brake to automatically hold. In my BMW I press the Auto Hold button to activate it and just press down a little harder when I break to have the brake hold automatically. I thought the Mercedes just didn't have this feature.
Well to my surprise today out of the blue I noticed that the word "HOLD" appeared in the main display and the brake was holding by itself. It happened again, but I haven't been able to recreate it afterwards. I thought if I pressed the brake pedal harder it would make it auto-hold, but that didn't seem to do it. So I can't figure out how to get it to auto hold again.
What am I doing wrong?
Thanks!
I'm beginning to wonder if there is a mechanical or sensor malfunction somewhere that is causing it to not register properly. I mean at a complete stop and I push down on the brake pedal it should technically go into hold.
I find it a nice feature to have when stopped at a long light, etc. Like I said, I originally thought the C class didn't have it, but saw it engage twice yesterday out of the blue, but have never been able to recreate it since.
Makes me think something is wrong and that I have to bring it back to the dealer for a check.
When I am braking and my car comes to a stop.... I give an extra push on the pedal and the vehicle is in " Hold" position.
It takes a bit of practice but now I use it all the time.
I also own a 2011 ML550 and unfortunately it does not have this feature.
I have really gotten used to this feature and its fantastic.
Works in all stop and go situations.
Note: This is my only car with this functionality. So I cannot compare how easy/difficult it is compared to others offering this feature.
Hill start assist
Hill start assist helps you when pulling away
forwards or in reverse on an uphill gradient. It
holds the vehicle for a short time after you
have removed your foot from the brake pedal.
This gives you enough time to move your foot
from the brake pedal to the accelerator pedal
and to depress it before the vehicle begins to
roll.
WARNING
After a short time, hill start assist will no longer
brake your vehicle and it could roll away.
There is a risk of an accident and injury.
Therefore, quickly move your foot from the
brake pedal to the accelerator pedal. Never
leave the vehicle when it is held by hill start
assist.
Remove your foot from the brake pedal.
The vehicle is then held for about a second.
Pull away.
Hill start assist is not active if:
you are pulling away on a level road or on a
downhill gradient.
the transmission is in position N.
160 Driving Driving and parking
the electric parking brake is applied.
ESP® is malfunctioning.
You can activate the HOLD function if all of
the following conditions are fulfilled:
the vehicle is stationary.
the engine is running or if it has been automatically
switched off by the ECO start/
stop function.
the driver's door is closed or your seat belt
is fastened.
the electric parking brake is released.
the transmission is in position D, R or N.
DISTRONIC PLUS is deactivated.
Driving systems Driving and parking
Activating the HOLD function
Make sure that the activation conditions
are met.
Depress the brake pedal.
Quickly depress the brake pedal further
until : appears in the multifunction display.
The HOLD function is activated. You can
release the brake pedal.
If depressing the brake pedal the first
time does not activate the HOLD function,
wait briefly and then try again.
Deactivating the HOLD function
The HOLD function is deactivated automatically
if:
you accelerate and the transmission is in
position D or R.
the transmission is in position P.
you depress the brake pedal again with a
certain amount of pressure until : disappears
from the multifunction display.
you secure the vehicle using the electric
parking brake.
you activate DISTRONIC PLUS.
After a time, the electric parking brake
secures the vehicle and relieves the service
brake. The HOLD function is then deactivated.
The electric parking brake automatically
secures the vehicle if the HOLD function is
activated and:
the driver's door is open and the driver's
seat belt is unfastened.
the engine is switched off, unless it is automatically
stop function.
a system malfunction occurs.
the power supply is not sufficient.
If a malfunction occurs, then the transmission
may be shifted into position P automatically
The feature is cool but I personally don't use it too often. I find that it's more comfortable to rest my foot on the brake than somewhere else. But I have long legs.
All I do is when at a stop, I just push the brake pedal down farther until the "Hold" light comes on the dash. This feature works in S+ as well.
Love the feature. I also like the fact I can put the parking brake on for extended waits and then just lightly tap to set off. I remember trying to do that during my test drive and the dealer accompanying me said it couldn't be done.
