DRL LED flickering
Old 01-05-2016, 11:35 PM
angeloxnet's Avatar
15 Mercedes C400, 12 Mercedes C250 coupe
DRL LED flickering
After work today i noticed my passenger side LED DRL started flickering,
it doesnt shut off but you can see it go slightly dimmer than normal then back to bright, its very subtle but after looking at my driverside it was only one side.
it was more noticeable when i put a black object in front where you can see the flicker in the light output from the DRL.
anyone else experience this before? if so anyone know what's up?
Old 01-06-2016, 03:03 AM
digitallust_aus's Avatar
W205 C250 Bluetec AMG Line
Funny you should post that, I noticed the exact same thing on my W205 the other evening when park up in front of my dark blue garage door...
Old 01-06-2016, 03:23 AM
DBOC205's Avatar
W205 C250BT
The DRL, like many LEDs use Pulse width modulation (PWM) to reduce thermal load and prolong life of the diode. If you get visible or inconsistent flicker (different to strobing) you probably need the controller checked or replaced.
Old 05-21-2019, 03:57 PM
tjbrum's Avatar
Does anyone know the location/part number of the drl module or controller?
Old 05-23-2019, 06:40 PM
MOMOSAM79's Avatar
W204 C300
The module is HLI
Quick Reply: DRL LED flickering
