Turbokits.com BOV Install
#51
2020 MB E350
Yes I read the instructions, but it didn't say the spring just would fall out all together if it was tilted upside down either. It just says be careful. Their are like three different parts that really easily could've fell off at anytime. You weren't rude at all, I was just wanting some advice. I found a spring at lowes and put it on. It was very close to the same as the one that fell in the bay.
#52
[QUOTE=15MBC300;6836277]Yes I read the instructions, but it didn't say the spring just would fall out all together if it was tilted upside down either. It just says be careful. Their are like three different parts that really easily could've fell off at anytime. You weren't rude at all, I was just wanting some advice. I found a spring at lowes and put it on. It
Where exaxctly is this located because i didnt see it on mine!
#54
2020 MB E350
It's on the stock blow off valve, once you take off the three bolts and pull out the black part which is the blow off valve or at least people are calling it the stock blow off valve there is a rod inside of it with a spring around it that is just loose and when you go to re-install it with the turbokits.com spacer on the other end don't tilt it downwards because the spring will just fall straight off into the bay of your engine.
#55
2020 MB E350
#57
futbol90x@gmail (07-22-2016)
#60
Question.
Is it possible (or just plain stupid) to install only one BOV on the c450? The instructions seem like the driver's side goes on very easy, but the passenger side looks like more stuff needs to be moved than I am comfortable with. Is there any issue with only installing one on my motor? Will it cause any unbalance within the intake? Will the sound be any less impressive?
