Command Video player
Old Feb 16, 2016 | 07:51 AM
NYbenzzz's Avatar
2016 C300
spent some time yesterday messing around with the Video player function of Command.
final results:
Movie DVD = works fine
Audio DVD = works fine
USB MP4 video files = only plays audio, detects it as mp3. Audio quality is much better than CD.
Memory card MP4 files = same as above
Iphone 6 plus videos over USB = doesn't work
Video CD = i haven't tried
DVD with MP4 files (such as music videos) = only plays audio.
now, i learned this via true TRIAL and ERROR (spent like 3 hours):
To make MP4 music videos playable:
grab your MP4 files and burn into a "DVD-VIDEO" using authoring software. basically you have to make it playable on any SET-TOP box. by set-top box, i'm talking about the most conventional set top boxes.
So the DVD gotta have chapters, etc.
if you just burn it as a regular file DVD (as in drag and dropping the MP4 files) only AUDIO will work, not video.
i used NERO VIDEO. keep in mind that NERO BURNING ROM will make it a regular DVD with MP4 files, so only audio will play. you need to use DVD editing/authoring software to prepare the files.
so currently i got a DVD in the cd slot with music videos for when i'm parked and bored to death.
Command hard drive is about half filled with MP3s.
and i use spotify from my iphone via bluetooth.
i'm good to go now.
Old Feb 16, 2016 | 11:30 AM
mvw's Avatar
mvw
2016 C450 AMG; 2015 Infiniti QX60
final results:
i'm good to go now.
lol. I spent a few minutes trying to figure out how to get a "DVD" to work until I remembered the car has a cd player. Been like a decade since I have used the cd player on a car and had totally blanked that there is one...
Old Feb 16, 2016 | 11:35 AM
NYbenzzz's Avatar
2016 C300
LOL
it's been a decade since the last time i burned a DVD.
first i drag and drop it and burned a DVD in like 5 minutes. that failed, the command dvd player was recognizing it as a mp3.
then i did my research and did it the proper DVD-Video way.
now i do have a monster gaming PC with multiple SSDs, and even so it took nearly 40 minutes to complete. now it works fine.
it was like i was re-learning everything again.
Old Feb 16, 2016 | 12:38 PM
MASSC450's Avatar
2026 GLE 53 Coupe
I wish the COMAND DVD player would play BluRay movies.
Old Feb 16, 2016 | 02:46 PM
cyberorth's Avatar
2018 AMG GTR, 2017 GLS63, 2019 C63s
It is so dumb that it can't in 2016th century!
Old Dec 18, 2016 | 11:41 PM
JaCe88's Avatar
GLE 300d (v167)
I thought the w205 COMAND is meant to be able to play various formats of video files on USB?
"MPEG, WMV, MOV, AVI, MP4" per http://moba.i.daimler.com/baix/cars/...er_09_85.shtml
Old Dec 19, 2016 | 03:45 PM
ManiacGT's Avatar
BMW e89 Z4 sDrive 35i & MB S205 C200 AMG Premium Plus
lol that you'd say dumb and 2016th century in the same sentence.
Old Dec 19, 2016 | 03:46 PM
ManiacGT's Avatar
it does, I've tried it.
Old Dec 19, 2016 | 05:06 PM
Hapa88's Avatar
2017 C300 Coupe (C205)
I have a few suggestions and will probably try this on my non-COMAND system when I get home because I had a similar problem when trying to play .MP4 files
1) Change the file names of all your .MP4 files to .M4V (or .m4v).
According to the COMAND manual, .mp4 files are treated as AAC file types (meaning they are treated as audio files by COMAND, hence why it may only be playing the audio part).
2) If that doesn't work, try putting the .m4v files (and even .mp4 videos as a test) in a directory called "Video" (but without the quotes). The COMAND manual states that after 64GB of memory is used on a medium then only folders with names "Music", "Pictures" and "Video" is supported.
Old Dec 20, 2016 | 06:59 PM
hpilot's Avatar
2015 C300, 2025 GLC300 4Matic
final results:
i'm good to go now.
I have a 128GB SD card and a USB thumb drive filled with mp4 music videos, and they play just fine. Why would you burn them to a DVD. Just make sure they are 720p. There are several threads that discuss this.
Old Jan 11, 2017 | 04:17 PM
whiteC3002016's Avatar
2016 Mercedes C300
Is there any work around for getting it to play videos from iphone via cable?
Old Jan 12, 2017 | 12:58 AM
MBGeek36's Avatar
2017 C300 4MATIC
Old Dec 6, 2017 | 02:45 PM
edrin's Avatar
b class 2016
hi need help
can i watch videos on b class 2016? just bought it
Old Jul 13, 2018 | 01:06 PM
Achilles1009's Avatar
C220
when i open Supported data formats on my MB 2015 c220 , doesn't show VIDEO but only MUSIC and IMAGES.... does this mean that i cant play dvd or videos ???
Old Jul 13, 2018 | 01:46 PM
edrin's Avatar
b class 2016
I think u cant
i guess u have audio 2.0 just like my b class of 2016. And that means u can only play music and pics. Check the info on ur car if its audio 2.0 u r screwed just like me. Sorry
Old Jul 13, 2018 | 06:33 PM
C220
Can e change it... or do sth 2 play videos ?
Old Jul 14, 2018 | 04:34 AM
edrin's Avatar
b class 2016
IT depends on ur budget
if u have enough money to spare yes u can change the all the console compartment. Its around 2-3000€. Also its not so much necesary cos u cant play it while driving. Maybe is better to buy a mp4 player they are cheap
