Wheel question 19x9.5 and 19x10
So i sold my 18" set and going for 19"
Now to the question cause i dont get it at all ...
Found a wheel that is 19x10 ET45 ... i guess this wont fit in the rear , or ?
And then 19x9.5 ET40 on another set ... will these fit or not ? also rear ...
The standard wheels are a 56 off set so 45 off set might work. I would suggest a trial fitment. If you interested in the tyre size you can go 225/45R19 front and 245/35R19 on the rear
i wont go for 19x10 ET45 rear ... found another wheel that i want more
so i guess it will be 19x8.5 in front and 19x9.5 rear , both with ET45 ... will that fit ?
or maybe going for 8.5 all around and wider rear tires ... but which size should i go for then, both in front and rear ?
thanks a lot for the help
It should fit, like I said before do a trial fitment first some wheels design cause the spokes to touch the calipers on the front so you will have to do a test fitment first. You can fit 225 and 245 on 8.5 but the 245 will bulge more than the 225
