Mode Carbon Product Showcase – Featured Item: W205 AMG-Sport Rear Diffuser
Former Vendor of MBWorld
E90 M3, F80 M3, C63 507, F90 M5
Mode Carbon W205 AMG-Sport Rear Diffuser
We are proud to announce our brand new Rear Diffuser offering for the W205 C-Class AMG Sport Models. This new design features bolder fins than the OEM component, for a more aggressive styling that will pair perfectly with our robust W205 Bootlid Spoiler. We were careful to make sure that the styling does not go over-the-top, while still accentuating the performance-oriented spirit of the new line of the AMG-Sport models. As always, our Mode Carbon Rear Diffuser will feature full tabs and utilize the factory mounting points for a seamless fit and finish that is guaranteed when you purchase any of our carbon fibre components.
Our Rear Diffuser is manufactured to the highest standard of quality, using our dry-layup vacuum infusion process. This process allows for an optimized resin composition ratio, yielding a dramatic weight advantage. The result is a pin-straight weave, which generates a more consistent level of structural integrity to maximize the overall rigidity of our carbon fiber. The Rear Diffuser is finished in a high-gloss UV protected clearcoat to protect it from the elements and prevent discoloration.
Key features:
- Fitment for W205 C450 AMG and W205 C-Class models with AMG Sport Package
- 100% pure carbon fiber
- Vacuum infusion, dry lay process
- Superior stiffness-to-weight ratio
- Pin straight weave
- UV protected high-gloss clear coat
Current :2018 E63S and a 2017 GLE 63S . Prior, CLA 250, C450 AMG, 2017 AMG C63S
Key features:
- Fitment for all W205 C450 AMG and C300 with Sport Package
- Comes with 3M tape pre-attached
Looks very nice! Price? How does it attach? Overlay or does the OEM diffuser need to be removed.
I agree on the looks. What worries me would be the attachment. This wouldn't be a cheap part I'm guessing. They say "Comes with 3M tape pre-attached" which seems to indicate it's glued onto the stock diffuser. That's an area of negative air pressure plus the chance of accumulated moisture. It's not exactly something you'd notice falling off the car when the sticky tape degrades.
This will fit all W205 C-Class models with the AMG Sport Package.
Edit: No 3M Tape!
This is a direct replacement for the OEM rear diffuser. The OEM rear diffuser is first completely removed, and then our carbon fibre rear diffuser is installed. The Mode Carbon Rear Diffuser features full carbon fiber tabs and utilizes all OEM mounting points in the bumper. No extra cutting/drilling/modification to your bumper is required. The construction of the Mode Carbon rear diffuser is 100% pure carbon fibre, no overlay.
PMs coming your way shortly!
