2016 Mercedes C450 AMG 4Matic Transmission Problems
Old Sep 12, 2016 | 02:45 PM
Mxjet1's Avatar
new owner
great info. having some of the same issues and mine only does it occasionally in sports + and at low speed, usually when i almost come to a stop and the start to accelerate the car again. Anyone think this is similar to all these other issues???
Old Nov 16, 2016 | 03:27 PM
zdonner's Avatar
2015 C63S
Took mine to the dealer, they told me today that since the other C450's they have do it that it's "Normal".
I told them because the other cars do it does not make it a "feature". It's a constant repeatable issue I was able to produce in their parking lot, consistently.
I'm preparing to call MB directly on this.
Old Nov 16, 2016 | 04:04 PM
sev7nflow's Avatar
2013 C250 Sport
i asked my dealer about this problem too, they said it was the transmission "learning" your driving habits and could take up to 20k miles for it to learn
Old Nov 16, 2016 | 04:35 PM
zdonner's Avatar
2015 C63S
That's bull, mine already has 20K on it and it's only
gotten worse.
Old Nov 16, 2016 | 04:52 PM
Mike5215's Avatar
2016 C300
Yeah, adaptive transmission changes are subtle and the system "learns" everything it's going to learn within 1,000 miles or so. 20k is absurd.
Old Nov 18, 2016 | 12:56 AM
Cosworth2000's Avatar
2022 E53 AMG
Hello everyone... So Mercedes-AMG found out what the problem was with my transmission. Yes, Mercedes-Benz could not figure it out since the C450 AMG transmission is modified by AMG for the dynamic drive and rear bios specs.
Anyways, Mercedes finally connected their data system to my car and it shows that the transmission was slipping in 2nd gear but no error code. Apparently this is normal as it allows the transmission to get ready for the 3rd gear. The only problem with my car is that it felt heavy when it slipped and now it's very light and most of time unnoticeable; which is the way the transmission is suppose to feel. Be aware that this slipping happens on all the gears but you may notice it in Comfort Mode and at slow take-off speed.
It came down to this problem: the transmission issue have been resolved by a replacement of the Transmission Clutch Solenoid which failed however the Mercedes diagnostic system did not register an error. Mercedes-AMG was sent my transmission data. It's a file of what the transmission is doing in code.
So the only group that was able to solve this matter was Mercedes-AMG in Germany.
Old Nov 18, 2016 | 01:21 AM
  #32
PeterUbers's Avatar
curious if it will come back despite this fix
Old Nov 21, 2016 | 08:52 PM
  #33
nvsocr7's Avatar
GLE 350 4MATIC
GLE 350 here, I have the same issues. The transmission is very clunky, not responsive, attempts to search for entirely too long. X5, S5, MDX do not have any of these problems and they are in the same price range. I've taken it to the dealer 3-4 times and reset the ECU myself. They tell me "theres nothing wrong" but the head mechanic actually admitted Mercedes thinks there's an issue between the transmission and engine computers talking to each other. There are quite a few people having this issue too. Our 2000 E320 runs like a dream compared to my GLE.
Old Nov 21, 2016 | 09:06 PM
  #34
nvsocr7's Avatar
GLE 350 4MATIC
Do you have any written documentation of this? I don't trust my dealer anymore (they told me excess road noise from my sunroof after using vent mode is "normal", it's not at least it should not be) and would like to take this to the dealer across town to see what they have to say about the transmission issue
Old Jan 17, 2017 | 09:33 AM
  #35
zdonner's Avatar
2015 C63S
Anyone who is having issues with the transmission shifting oddly/slipping please call MB Customer Service and report it. I've started the ball rolling but they claim there have been little/no reports of any other issues. I've escalated this as high as I can to the "Market Engineer" (I believe they called him/her?) and they say it's software related. Due to the lack of complaints it isn't a high priority to send out an update.
Thanks,
Old Jan 17, 2017 | 09:37 AM
  #36
removedCFGaccount's Avatar
Former Member
CLS
In my experience, it is cured by software. Pm me your email address and I'll refer you to a guy who may help. Basically, a ptss case is begun, a technical specialist in Germany considers the symptoms you report and writes a patch and then an adaptive reset is done locally while driving the car!
Don't let them BS you, it is common enough that mercedes Germany knows how to fix it.
Old Jan 17, 2017 | 10:30 AM
  #37
Former Member
CLS
Thanks for your pm. As I understand it, the resolution has two parts, each of which is essential: a software patch prepared in and forwarded from Germany, then "tuned" to your car by driving with an external computer in place so that the local tech can see how the patch reacts to real conditions and modify it as required. I suggest your service manager has yet to find the right guy in Germany.
Old Jan 21, 2017 | 04:52 AM
  #38
AmrDXB's Avatar
C 250 (W205)
I just purchased a C250 a few weeks back. Only 1 week ago at 1500 KMs I started feeling a slightly sluggish transmission between D2 & D3. This is not constant and sometimes it doesn't exist at all (I believe depending on the temperature). My car has a 7G transmission.
So since I bought the car from a different city than the one I live in. I called the service center to see what they have to say. The service adviser informed me that this is normal and if there's a problem with my transmission I will see an error message.
My problem is really mild and doesn't seem as bad as others are describing. It only happens in comfort. What do you guys advise me to do ?
Old Jan 21, 2017 | 08:51 AM
  #39
Former Member
CLS
ON the C450, no error code or message ever appears.
Old Apr 1, 2017 | 12:12 PM
  #40
imj0257's Avatar
C450 AMG
I just purchased a C450 a few weeks ago with 9k miles on it. In the 2 weeks I've had the car I've noticed this too. It has happened 2 times.. seems like at random. Both times it was in Sport+ mode and I was at a stop (in a parking lot or side street). As soon as I started to accelerate it would jerk for 2-3 seconds, eventually becoming smooth again. I thought I was losing my mind the first time it happened but then it happened again today and I knew it must be something quirky going on. It's also awkward because other people see you jerking the car like you don't know how to drive it or something...
So.. just wondering if there truly is a fix. If i tell the MB dealership about it, will they know what I'm talking about and know what to fix? They might just say 'everything looks normal'. Anything special I should tell them?
Thanks.
Old Apr 1, 2017 | 12:29 PM
  #41
Former Member
CLS
Yes, it can be fixed in one day, and no, most dealers don't know how. Pm me for details.
Old Apr 1, 2017 | 12:33 PM
  #42
imj0257's Avatar
C450 AMG
I just found this thread https://mbworld.org/forums/c-class-w...plus-mode.html which is more my problem than this thread.. I think. Mine is jerky is Sports+ whereas this OP I believe has slight slippage in Comfort.
A couple posts in the other thread say it is normal in Sport+ since it is a sport tuned transmission....
Old Apr 1, 2017 | 02:03 PM
  #43
2022 E53 AMG
Hello Everyone,
​​​​​​it would seem that Mercedes is aware of the problem since someone posted a video on YouTube advising the first steps to correct the issue. More than just a part change or software update.
https://youtu.be/0haHOcgujtY
Old Apr 1, 2017 | 02:23 PM
  #44
Former Member
CLS
Didn't you go to Thornhill?
What did they do?
MB has a service bulletin which cautions against parts replacement, so....
Old Apr 1, 2017 | 06:26 PM
  #45
JBMCL's Avatar
Benz
Mines pretty jerky in Comfort..
'16 C300
Old Apr 1, 2017 | 07:17 PM
  #46
sean1.8t's Avatar
c-fo-fiddy
Well, got my C450 AMG back.. Funny...still the same problem. I'm pissed as my in-car camera caught the mechanics speeding all over the place. Guy gets into my car and states "oh, the car has over 360hp". What? MB Mechanic does not know how the C450 is built? He takes my vehicle up to 115km on Hwy 7, then slams on the breaks at one point so the red light camera would not catch him. He then speeds through traffic, zooming in and out. I told them my transmission slips in 2nd gear. How does he expect to see what is going on when he is racing around the streets. So now, they are coming to bring me a loaner again and this time I need to sit down with the foreman and walk him through the issue. They drove my car around 2x, had the hood up, washed the car and told me it was okay. Poor service since I have bought this vehicle and it's only getting worse. I have had better service while owning a Mazda than a Benz and this should not be. What upsets me the most is that my car had not even reach the break-in point and this guy was racing my vehicle when I never did that since I bought it. Yeah, you know I'm not going to stop there as I have LIVE footage of his abuse to my vehicle.
Can you post the video of the tech rallying the car? I'd love to see. I really gotta get a dash cam installed before I take my car in for its first service. You can't trust anyone these days
Also, there is no break in period for non AMG cars. They break in the motors on a stand before they install them into the cars. So you can rip it up to redline on mile 1
Old Apr 1, 2017 | 09:32 PM
  #47
Mike5215's Avatar
2016 C300
I was on a forum once for performance cars. A guy was pissed because when he got his car back from a service visit the fuel was down a quarter tank and there were fresh rubber shavings in the rear wheel wells. Some guys were telling him to lighten up...the car was built for burn outs after all.
But one guy made a great point. He said your wife's vagina is built for sex. So is it okay if her gynecologist screws her at her next exam?
Bottom line, I can tear the car up if I choose. The shop cannot.
Old Dec 13, 2019 | 06:44 PM
  #48
Matthew Cohen's Avatar
C450 AMG
My car is now having the same issue as OP, except it does it independent of temperature. Also have a 2016 c450
First experienced this 11/28, had a service apptment on 12/11. Dealer updated some engine control module(will update when I can check the paperwork). Car is better, the skipping in 2nd is less frequent and more mild when it does happen, however the problem has definitely not been resolved. I'm still getting rpm drops in 2nd with no gear change occuring. Will reply with what worked for me if they can fix it.
Old Jul 23, 2020 | 10:17 PM
  #49
DrivingForce's Avatar
2011 C300 Sport, 6M, Dynamic Handling Pack
How common are these issues? Have a deposit on a C450 out of warranty but I have a 7 day return so I will be on the lookout for potential issues during that 7 days.
Old Jul 24, 2020 | 12:05 AM
  #50
GringoBling's Avatar
C400
uncommon, there was a software flash to fix it anyways.
