buying rims help with fitting + sensors
Subscribe
May 31, 2016 | 09:16 PM
So this is my first benz!!! i have 2015 300c.
Im keeping my OEM rims/tires in storage for the winter so that means ill need new wheel sensors. Do in need to take it to the dealer to relearn the new sensors? Also, whats the part number for the wheel sensors?
Will these wheels fit my car without any problems?
Model Name: 195112MERM143MB / 195112MERM143MBR
Wheel Size: F 19x8.5 R 19x9.5
Wheel Fitment: This set up is for 2008 and newer C Class 2009 and newer CLK and 2011 and Newer E Class and More!
Tire Size:
Please See Other Add!
Center Caps: Wheels Pictured with OEM Factory Caps!
Finish: Matte Black Machined Stripe
Bolt Pattern: 5x112
Offset:: F +45 R +45
TPMS Compatible: Yes
Quantity : 4
Condition: Brand New in the Box
Availability: In Stock. Usually Ships within 1 Business Day
Reply 0
May 31, 2016 | 09:23 PM
Those wheel specs look good. You can pick up used sensors on EBay. Just make sure you get a set with the correct frequency for your car. They do not need to be activated or paired to the car to work. Should pick them right up.
Reply 1
May 31, 2016 | 09:25 PM
Quote: Those wheel specs look good. You can pick up used sensors on EBay. Just make sure you get a set with the correct frequency for your car. They do not need to be activated or paired to the car to work. Should pick them right up.
i should be good to go then bro? what you by frequency bro?
Reply 0
May 31, 2016 | 09:34 PM
Sensors transmit radio data to the car. The car is set to receive a specific frequency from the sensors so they have to be on the same channel. Not sure what that frequency is for the W205. haven't changed my sensors yet.
Reply 0
Subscribe
Currently Active Users (1)
