How to upgrade the base sound system
Rating: Thread Rating: 2 votes, 4.00 average.
Old 06-17-2016, 07:24 PM
  #51
Mike5215's Avatar
2016 C300
That's a problem. But I think he was able to order one so maybe it's just a new addition.
Old 06-17-2016, 07:32 PM
  #52
vladarh's Avatar
E350e W213
Originally Posted by Mike5215
So I've lost track of what you're doing. Speaker wise what are you replacing and with what? Or staying stock and seeing what it needs after the DSP?
I replaced the fronts with Focals. I'll do the amp next and then see if I need to do something with the woofer or the back doors (most likely the back doors will be coax).
As for the Match P&P they say it only works on the W204 Audio20 but I found somewhere that the connectors are the same for Audio20 in W204 and W205 (and they look exactly the same).
If it doesn't work I'll try disassembling the yellow ISO from the stock connector. I think it can come out.
Old 06-17-2016, 08:04 PM
  #53
Mike5215's Avatar
2016 C300
Yeah, the joy of being an audio pioneer. I'm pretty psyched about there being a good upgrade path for the A20. I get a couple of emails a month on the blog asking for one and I'm basically guessing.
Are you doing an external sub/amp in the trunk?
Old 06-17-2016, 08:53 PM
  #54
Royce118's Avatar
15 E200CGI SPORT
Yeah, that's a recent revelation on the 2 ohm. At least when harman/kardon used essentially the same speaker in the W221 they were 4 ohm. My error for assuming they'd be the same. I need to check the resistance in the 4" I took out of the Burmester as well.
So in your system with the Match DSP the website shows it as a straight DSP with low voltage RCA out, presumably for an amplifier. Did you need to buy an amp for your set up?
Edit: Found the version with the amp included.
The really cool thing about the Match is the available vehicle specific harness. Huge labor saver. Otherwise, on paper at least, it does seem to match the Audison in terms of power and features. How much for it plus the custom harness?
Mike, the prima does in fact comes with a plug and play harness kit. I can confirm this because I am using it on my car.
Old 06-17-2016, 09:32 PM
  #55
Mike5215's Avatar
2016 C300
Yeah, at the time it was my shop's first Prima in a 221 S Class and the harness was almost $700, or roughly 7 hours of labor. We decided to skip it. The spot we picked to mount the Prima on the 205 was right on top of the factory amp so they did their own connections on that one too.
Old 06-18-2016, 04:15 AM
  #56
vladarh's Avatar
E350e W213
Not right now. I'll see how the amp setup helps the MB Frontbass
If it can't be fixed then I'll have to go external.
Old 06-18-2016, 09:58 AM
  #57
Mike5215's Avatar
2016 C300
With the DSP you may be able to rein it in enough to have it play from sub territory up into the mid bass without getting sloppy but it's tough. It'll definitely sound better than what you have now though.
Old 06-19-2016, 11:54 AM
  #58
CA_GLC's Avatar
GLC300
Where do you guys get the Audison Prima's? I'm in the U.S. and can't find them anywhere except from Italy on eBay. Doesn't look like they can ship the 5.9 to U.S.
I'm psyched to get my Focal KRS100 components installed next week. Audio shop said they can try to do some custom tuning. Eventually I want to get the rear doors done with either the KRS100's or the ES100K's without tweeters.
I thought about the Alpine DSP for $700 USD...but it does not have amp. My GLC is very similar to the W205, so I'm guessing the stock amp is under the center console. Vladar - how do you like the Focals in front???
Old 06-19-2016, 01:47 PM
  #59
Mike5215's Avatar
2016 C300
I live in a little college town in the middle of Florida and my local audio shop carries (or can order) Audison, Focal, etc. Might just need to call some shops in your area.
Old 06-19-2016, 03:54 PM
  #60
vladarh's Avatar
E350e W213
There's a difference when you install them, the mid frequencies are crisper and you get the highs which weren't there. But you feel a bit disappointed when you realize that they're not exploited to the fullest. And with them the terrible bass stands out even more. So I can't really tell before the amp is in. But they are fantastic speakers, so I'm sure I'll love them.
Old 06-19-2016, 04:08 PM
  #61
Mike5215's Avatar
2016 C300
Yeah, the best part of the KRS100 are the tweeters. I was originally going to get the BMW Focal drop ins for my 221 but the local Focal rep recommended the KRS just for the step up in the tweeters. The 4" were six of one/half dozen etc.
I think a lot of owners think the answer to the A20 is high end speakers, but really you need to address the DSP first.
vladarh (06-20-2016)
Old 06-21-2016, 04:54 PM
  #62
Seranex's Avatar
C180D 2016
Following this too for the match dsp ,
posted in the other thread as well, but with stock a20 speakers, adding the match dsp should be a first step prior trying to upgrade the speakers themselves?
Old 06-21-2016, 05:12 PM
  #63
Mike5215's Avatar
2016 C300
Yeah, I'd start there and see how much improvement you can get just by some EQ. I'd say next would be to add tweeters in the front door sail panels and a sub/amp in the trunk.
I would just grab a set of used Harmon/Kardon tweets off eBay and run them off the 4" OEM door speakers.
Seranex (06-21-2016)
Old 06-21-2016, 05:30 PM
  #64
Seranex's Avatar
C180D 2016
sweet will give that a try soon , secretly waiting on vladarh harness fitting test xD of the match dsp one (do hope the harness for the w204 audio20 is the same as the w205). going by pics they do seem the same to me though.
Old 06-21-2016, 05:41 PM
  #65
Mike5215's Avatar
2016 C300
Yep. You never know how the pin-outs are going to match up though W204 vs 205, even if the harnesses look identical. That's the real hurdle. He can always disassemble the connector and move pins around if he has to.
Old 06-22-2016, 10:19 AM
  #66
Seranex's Avatar
C180D 2016
Planning on getting the Match M 5DSP and changing up the speakers. Any recommendations on speakers? I was looking at the bmw drop ins:
IFBMW-S
IFBMW-C
IFBMW-SUB
Can get those for about 550EUR, just doubtful about the built in dept. Afaik:
front built in dept is larger than the rear doors (same on s205? I'll need to check that soonish). But the IFBMW-C will have a built in depth of about 5CM (according to the seller) with the same magnet diameter and afaik same depth as the Focal PC100 which someone tried to fit, and failed for the rear doors. :/
Any other suggestions for the speakers? at this point, I just want to replace the standard ones.
Old 06-22-2016, 11:16 AM
  #67
CA_GLC's Avatar
GLC300
@Seranex - do you have a link for the thread(s) about the Match aka Helix amps? Actually my local audio shop recommended this one for $900 but I did not ask the name of the specific model.
The 5DSP looks tiny but I like how it does not put out too much power and has the DSP built-in. Or I saw the PP41DSP had same 35W output for the 4 door speakers >
http://www.audiotec-fischer.de/lng/e.../pp-41dsp.html
You should go with the Focal KRS100 components if you can afford, many people here have done it. Rear doors are more iffy , less space. I might try the ES100K's later when I can afford it.
Old 06-22-2016, 11:26 AM
  #68
Seranex's Avatar
C180D 2016
well the Match M 5DSP was bought by Vladarh (in this thread ) supposedly with matching adapter for the audio20 (W204 Audio20 connection is supposedly the same as for the W205). But I don't think he tried to connect it yet. I haven't bought anything yet myself.
I could do the Focal KRS100 components but did some reading on various threads and the pics where someone put the crossover: front door panel didn't match with someone else's front door panels , drop ins just seem easier xD . I need to get around taking off the front/rear door panels either this or next weekend to be sure of it all.
Focal KRS100's will bump my front door speaker cost by 100EUR only (compared to the IFBMW-S), isn't that much, but is it really worth the money?
  #69
Mike5215's Avatar
2016 C300
IFBMW-S
IFBMW-C
IFBMW-SUB
Bear in mind the factory speakers are 2 ohm, and any aftermarket replacement is going to be 4 ohm. That means the amp's power will effectively be halved. Replacing speakers also doesn't address the main problem, which is the factory EQ and a lack of any mid-bass woofers.
I think the Focals (or anything decent) will be power-starved on that amp and the incremental improvement won't justify the cost. If you want the Focals, just do the fronts to get the tweeters and leave the rears stock. I'd do the KRS100 vs the drop in BMW type...just a minor mod on the mount, but much better tweets.
bukusuma (06-25-2016)
Old 06-22-2016, 11:43 AM
  #70
Seranex's Avatar
C180D 2016
Ok! thanks for the info, will look at the KRS100. Which other (dsp)amp do you suggest for the base audio?
Old 06-22-2016, 12:00 PM
  #71
Mike5215's Avatar
2016 C300
Waiting to see how the Match unit works out...
Old 06-22-2016, 03:51 PM
  #72
vladarh's Avatar
E350e W213
Here I am. I got the package today. I bought the amp, the harness for the W204 and the ISO harness:
The Match M 5DSP amp and the PP-AC 13a harness from Match.
Match PP-ISO cable
Old 06-22-2016, 03:58 PM
  #73
vladarh's Avatar
E350e W213
I have good news and bad. The good thing is that the W204 harness works perfectly. Installed it, plug&play and everything works.
Now for the bad news. The stock harness coming from the HU has 5 pairs of cables coming out of the 4x2 standard ISO connector. Before connecting the expensive amp I measured the resistance on all 5 pairs of wires coming out. The four regular pairs (FL, FR, RL, RR) all gave a result under 1ohm (too low for my multimeter) and the 5th pair gave 6,5ohm. Either my multimeter is seriously broken or there's something wrong with the connections. I'll go to my local audio shop to have it measured there.
What's even stranger is that when I disconnected the 5th pair (coming out of FL+ and FR-) the Audio 20 HU went into protected mode and turned off.
I don't get what's going on.
Old 06-22-2016, 07:43 PM
  #74
Mike5215's Avatar
2016 C300
Hmmm. If the 8" shallow mount sub in the footwell is the same harman/kardon dual coil sub I'm familiar with, it may have a 6.5 ohm resistance. Not sure why you're getting nothing from the cabin speakers. That protection fault can happen if the leads touch each other or one of them touches ground.
Are you hesitant to connect the amp due to the risk of overheating the amp given the low resistance? I think you'd be okay running it for a short period and see if it heats up.
Old 06-23-2016, 02:29 AM
  #75
vladarh's Avatar
E350e W213
That's exactly it. I think it was designed for 4+ ohm speakers. But I guess the inbuilt protection will kick in if they're lower. As I said I'll drop by the local car audio shop and see what they say.
You have already rated this thread Rating: Thread Rating: 2 votes, 4.00 average.
Quick Reply: How to upgrade the base sound system
