Weistec M274 C 300 Downpipe, VTA, and Tune
Former Vendor of MBWorld
We are happy to offer a whole new lineup for the W205 C300 owners.
M274 Downpipe
The downpipe was designed with the most sophisticated Computer Aided Design tools to ensure excellent fitment. The downpipe features 3 inch diameter piping and a laser cut precision flange to mate with factory mounting points, giving this system a perfect fit. Our M274 Downpipe features a CNC Machined 304 stainless steel turbine flange to mate with the turbo perfectly using the OEM clamp. The M274 Downpipe connects to the rest of the exhaust using an OEM style adapter for a simple bolt in installation.
KEY FEATURES:
http://weistec.com/all/c/c300/2015-p...pipe-c300.html
*Product may not be emissions compliant. Check local laws prior to installation.
M274 VTA
The Weistec M274 VTA (Vent to Atmosphere) Adapter is designed and manufactured as a complete and simple bolt on solution for attaining the "blow-off" sound that many people are fond of on turbocharged vehicles. The M274 engine comes equipped with an electronically actuated bypass valve in the turbo compressor cover that recirculates back into the compressor inlet for near silent operation. With the M274 VTA Adapter, there will be no check engine light as the factory valve is still used, and no tuning or ECU calibration is required.
KEY FEATURES:
http://weistec.com/all/c/c300/2015-p...a-adapter.html
M274 ECU Calibration
The Weistec M274 ECU upgrade for the 2015+ C300 provides gains across the entire powerband resulting a vehicle that is more fun to drive in all driving situations. The M274 ECU upgrade can be paired with our M274 Downpipe for further improved response and exhaust note.
KEY FEATURES:
http://weistec.com/all/c/c300/2015-p...u-upgrade.html
M274 Downpipe
KEY FEATURES:
- 100% mandrel bent and TIG welded
- Constructed of low carbon 304 Stainless Steel
- CNC machined 304SS turbine flange
- Laser cut mounting bracket
- Fully brushed finish
- Bolt-on installation
- 1 hour instal time
- Improved exhaust note
- Improved exhaust flow
- Improved turbo response
M274 VTA
KEY FEATURES:
- 100% Bolt-On Solution
- No Check Engine Light
- Easy 30 Minute Installation
- CNC Machined Aluminum
- Hard Anodized to Military Spec
- Engineered and Manufactured in USA
KEY FEATURES:
- Increased HP and Torque
- Improved Throttle Response
- Optimized Fuel and Spark
Thanks will add it to the classcbenz/c450 site any plans on a version for the c450? A lot of us with exhausts would love to tune our cars!
