Tire rotation
Old Aug 9, 2016 | 06:42 PM
ajb723's Avatar
C450 2016
Tire rotation
Perhaps a silly question.. should you rotate the run-flat tires from side to side on a C450 since the difference in size makes it impossible to rotate front and back.
Old Aug 9, 2016 | 11:31 PM
Shadwell's Avatar
C300 S205 AMG, GLA 45 AMG
They are directional so no......
Old Aug 9, 2016 | 11:42 PM
ajb723's Avatar
C450 2016
That makes sense. The dealer told me that rotation will prolong the life of the tires. But you can't do that since front and rear are of different size.
Old Aug 9, 2016 | 11:50 PM
Shadwell's Avatar
What they should have told you was to maintain correct pressure, and come the time to change not to assume to replace with like...
I will be replacing my continental sports contact 5's with Hankook Venus Evo S2... Half the price and only a few percent lower performing in independent tests ... Oh and non run flat for comfort and ride improvements...
Old Aug 9, 2016 | 11:54 PM
ajb723's Avatar
C450 2016
Right- BUT... Is it ok to change brands on a leased vehicle? And to use non run-flats would require a spare , but I I don't want to give up the trunk space
Old Aug 9, 2016 | 11:59 PM
Shadwell's Avatar
Depends on the terms of your lease...
Or if you will burn through the second set before the end switch back to ORM before the return ... Depends on your mileage..
Re boot space... Tyre weld / slime x2 and a plug kit ...
Old Aug 10, 2016 | 10:35 AM
topsider's Avatar
2015 C300 Sport 4MATIC
I took my runflats off, bought non runflats and I will put the runflats back on when I turn in the car at the end of the lease. I had bent rims fixed 7 times and was tired of it. 4 times under warranty and 3 times i had to pay for
Old Aug 10, 2016 | 12:16 PM
ajb723's Avatar
C450 2016
Were your tires 18 in. or 19 in? What did you do for a spare?
Old Aug 10, 2016 | 12:30 PM
Mikey53's Avatar
Veteran: Air Force
2016 C300 4Matic traded in for a 2022 E450 Coupe
Spare = 1-800-MB-comegetme
or
AAA
Old Aug 10, 2016 | 03:05 PM
topsider's Avatar
If I get a flat ill call a truck. I'm on 18's, the new tires really helped with ride comfort
