2017 C300 Coupe / purge line kinked
Old Sep 2, 2016 | 12:47 PM
RickP330's Avatar
2019 GLA 250 - I am in purgatory right now...
Hello All,
Not having a great experience with this car so far. Airmatic suspension failed within 1 mile of the dealership when I Picked it up, Right Rear strut had to be replaced. Less than 10 miles on the clock. Now at 800 miles the CEL came on and they said they found a kinked purge line which needed to be replaced. Please see the attached. What is this line, where is it located and what does it look like? It's apparently so new the parts had to be ordered from Germany and I need to go back and have it installed.
Other than these issues I really love the car, but I would like to know what this is which needs to be replaced.
Much TIA
Rick
Here is the description:
LABOR------------------------------------------------------------------------------
J# 1 07MBZZCK CK. ENGINE LIGHT ON HOURS: 1.60 TECH(S):8431 WARRANTY
CLIENT STATES CHECK ENGINE LIGHT WAS ON A FEW DAYS,WENT OFF
YESTERDAY.
KINK IN PURGE LINE
COMFIRMED COMPLAINT ATTATCHED SDS AND BATTERY CHARGER RAN
QUICK TEST. FOUND CODE P04F000 CHECKED AND FOUND DTB
LI47.30-P-060249. AS PER DTB CHECKED FOR DAMAGE OF WIDE
OPEN THROTTLE PURGE LINE. AFTER INSPECTING ENTIRE LINE FOUND
LINK IN PURGE LINE FROM PURGE VALVE TO PRESSURE SENSOR. R&R
PURGE LINE FROM PURGE VALVE TO PRESSURE SENSOR. PERFORMED
TEST THROUGH SDS AND TEST PASSED.
PARTS------QTY---FP-NUMBER---------------DESCRIPTION--------------------UNIT PRICE-
1 205-471-01-15 PURGE LINE WARRANTY
TOTAL - PARTS 0.00
Old Sep 2, 2016 | 01:24 PM
DapperStyle's Avatar
2014 C300
Originally Posted by RickP330
Hello All,
Much TIA
Rick
Not sure what is required for repair but Rick I implore you to take down that invoice and remove your name and any other contact info of yours off of it before putting it online!
