C450 Static LED Headlight Adjustment
2016 C450 AMG
I tried searching around to see if this question has been posted, but can't find anything.
I noticed that the driver side of my static LED headlight (non-auto-leveling) is aimed higher than the passenger side. I'd like to make an adjustment to bring it down a bit. When I looked under the hood, there is a phillips-type screw behind the headlight assembly, which I did play with, but that only adjusts the left and right aim.
Does anyone know how else I can adjust the level? I suppose I could bring it in to the dealer and have them make the adjustment, but for what seems like should be a simple adjustment, I'd like to do it myself, if possible.
I want to adjust mine as they are aimed low, my SA said I could just do it myself versus paying the labor rate at the dealer. Im guessing if i want them higher, I only want to use the Height screw right? does the other one adjust how wide they reach or something?
2016 C450 AMG
The other screw adjusts the left/right aim. In a sense, it is kind of like adjusting the width like you said.
Hi, can someone give me a hand with this please? I can loosen screw H however that just appears to be a screw to attach the whole light fitting, loosening that leaves the headlight loose and tightening it back up just returns the headlight distance to where it was.
What am I missing?
Thanks.
What am I missing?
Thanks.
