Opening windows + sunroof with key?
Old Sep 17, 2016 | 07:51 PM
jmillar82's Avatar
Mazda 3
Hey guys,
I love the feature on my C200 where you can open/close all windows + sunroof with the key, but wondering exactly how it works?
Sometimes I can get it to work easily, other times I have to try 3 or 4 times before I get it. Is there a set sequence I need to stick to, or do you need to be within a certain distance of the car etc etc?
Cheers!
Old Sep 17, 2016 | 09:25 PM
Gungaslow's Avatar
2017 C43 sedan
I think you have to point the key towards the front door handles
Old Sep 17, 2016 | 10:14 PM
Jadis's Avatar
C300W4
I think what you are experiencing is that when the interior sunroof cover is closed, holding down the button on your key fob first must be held down until it fully retracts. Then, you must let go, and push and hold it down again for the windows and sunroof to begin opening.
Since you are usually outside the car when this happens you might not notice the sunroof cover retracting inside and end up thinking it's not working.
If your sunroof cover is already fully retracted, then the windows and sunroof start opening immediately.
Thus, people may end up thinking it sometimes works and sometimes does not.
Old Sep 17, 2016 | 11:23 PM
Mike5215's Avatar
2016 C300
On the S it's an IR signal (not radio like the other key fob functions) and bright sunlight can interfere. You need to be about 10" away and pointed directly at the little square receiver in the handle. Not sure it's the same on the 205. On the S it also starts the driver's seat cooling function.
Old Sep 18, 2016 | 12:56 AM
jmillar82's Avatar
Mazda 3
Thanks for the explanation - that makes sense!!!
Thanks a lot
