Auto start/stop delay
Is there a way to delay a few seconds the auto start/stop after the car stops?
In a stop and go traffic, there are moments when you need to stop the car just a second before the car in font starts moving. The start/stop function will stop the engine as soon the car stops, and starts again the engine in less than a second.
In heavy traffic auto start/stop is a great option, but in medium-heavy traffic I'm not sure.
Best regards!
Best regards!
I try with very light pressure, just enough to stop the car in a parking lot, engine will stop no matter what after car stops.
Also when parking the engine will stop and start several times, this usually happens when slow parking to prevent hitting the front bumper... people just think this is a manual! they think engine is stalling because I'm not using the clutch correctly... WTF!
best regards!
best regards!
its been discussed on here endlessly. To the best of my knowledge you can't disable this via the cars own settings. It would need to be coded by a dealer or someone with appropriate equipment.
you can of course disable it in individual mode (agility) but that's more button presses than the single press of the start stop when you get in the car
There's a bit configuration in the engine module which allows the agility select to either remember for 4 hours, remember permanently, or to default back to Comfort after each ignition cycle. The bit is easy enough to set with Vediamo, but the modules are locked - so unless you have the seed/key algorithm or required files to unlock it you won't be able to write the config change back to the car.
