Dead Battery Already?
any my accessories plugged; in dash camera that stays in after ignition off, Bluetooth OBD2 module that bleed current continuously??
If none of those it's possible to have a faulty battery..
If if it happens again you have a short somewhere... And that's down to merc to track down...
As as an aside I bought a Bosch smart charger to top up the batteries every few weeks to avoid issues.
docthe same in the motor bike and its batteries last over 5 years..
Out of interest, is there a separate battery for the engine since there is a "quite large" battery to run the car?
It's positioned in the rear. Under the hood you will find a special contact that is connected to the 12V battery so you can use starter cables.
