Unable to get into Homelink programming mode
Old Nov 29, 2016 | 06:54 PM
sportflyer10's Avatar
Ford C max , C300 4-matic
I turn smart key to posn 2, then pressed the homelink button button , indicator light immediately turns yellow. When I release the button, it does not flash . What can I try next?
I fixed the problem by first clearing the codes . Then the programming proceeded as normal
Old Nov 29, 2016 | 07:39 PM
Jawknee_5's Avatar
C400
It was a little tricky for me when I connected my home link to my garage. There are a bunch of videos out there on youtube that you can look up.
In my situation, I hit the two buttons on the outside (underneath the mirror) to clear the code. Then, I hit the program button on the garage door (should be located in the housing, usually a green button). Hold that button for 10 seconds and run back into the car and hit position 4 button to program.
I did this over and over and it didn't appear to work. Finally, I took the garage door opener from my other car and as I click the button to close the door, I held the position 4 button on the home link and that work.
hope this helps....it's a little tricky but like i said, there are a bunch of videos on youtube pertaining to this.
Old Nov 29, 2016 | 11:09 PM
After I cleared the memory code( pressing button 1&3) , I started the complete programming sequence again and it worked. I think MB manual should have advised to clear the code first before attempting the programming sequence.
Old Nov 30, 2016 | 09:49 AM
skhan007's Avatar
2016 C300
I was curious about this, as well. I found this MB video with step-by-step instructions:
http://www.keenanmercedes.com/how-to...door-opener-2/
Old Nov 30, 2016 | 10:06 AM
The most important first step was to clear the memory of codes. After that follow the steps in the manual and it works .
Old Nov 30, 2016 | 10:36 AM
Mikey53's Avatar
Veteran: Air Force
2016 C300 4Matic traded in for a 2022 E450 Coupe
I just drove a couple of blocks from the house. Pushed the buttons on the garage door remote and car homelink until it flashed.....bingo Programmed.
Old Nov 30, 2016 | 11:21 PM
Darrington's Avatar
2015 C400
I wasted over half an hour trying to get it to work, running back and forth from the car to the garage opener. Part of my issue is I don't read directions thoroughly. Then I watched the 3 minute video by MB, and completed it in 5 minutes.
Old Dec 1, 2016 | 07:29 AM
pjw1967's Avatar
2023 GLE3502W, 2024 GLC3002W, 1967 Pontiac GTO 4 sp (sold...sniff)
If I do read the Directions, I start on page 4.....
