C450 Wheel Fitament
C450 Wheel Fitament
Curious if anyone knows the answer to this as i can't find much on aftermarket wheels for the C450
Could 19"x8.5" with offset et35 square set-up fit the C450?
Pretty sure up front it would work, would like some input on the rear.
In front, 8,5j wide, you need ET30, so for these wheels you need 5mm spacers.
On the rear, 8,5j ET35 will fit perfectly. Original it's ET52, so the weels come 17mm more to the outside, so they will fill the wheel arches perfectly!
if he goes with ET 35 in the rear will he not increase the wheel gap? just wondering...
