C300 2016 Service light reset
Is it possible reset Service A light for Mercedes C300 2016 ?
I do have Carly for Mercedes It does not have this function.
This is KeyLess model.
Read instructions here. Ignition position 1 is pressing the start button once without your foot on the brake.
Ignition position 2 is pressing the start button a second time without your foot on the brake.
http://oilreset.com/2015-mercedes-c-...nterval-reset/
To reset the 2015 Mercedes C-Class service interval, please follow these instructions:
1. Turn the ignition to position 1 (one position before starting the engine).
2. Press the system selection button (house icon located on the left of the steering wheel) repeatedly until the menu item TRIP is highlighted in the multi-function display. Within 5 seconds, press the OK button.
3. Press and hold phone button and then within 1 second press and hold down the OK button. Hold for 5 seconds then the workshop menu will be displayed "Vehicle data, Dynamometer Test, Change Brake Lining, ASSYST PLUS and Head-up Display".
4. Press the DOWN arrow repeatedly until ASSYST PLUS is highlighted and confirm with the OK button.
5. Press the DOWN arrow to highlight FULL SERVICE and confirm with the OK button.
6. Press the DOWN arrow repeatedly until CONFIRM SERV is highlighted and confirm with the OK button.
7. Specifiy engine oil used with the UP arrow and confirm with the OK button.
8. Press the DOWN arrow repeatedly until YES is highlighted and confirm with the OK button.
9. Press the DOWN arrow repeatedly until CONFIRM is highlighted and confirm with the OK button. "Full service completed" appears in the multi-function display.
10. Press the BACK (curved left arrow) button repeatedly until the standard display (total distance) appears in the display.
11. Turn the ignition off and then start the engine to verify the indicator has been reset.
*Close all doors, windows, hood and trunk when performing reset
Step 3 contains a mistake.
In Step 3 the words "within 1 second" should be omitted. It doesn't work when you do it that way. The video in this same thread shows the technician waiting over a second. Also, this post on another forum omits this phrase: https://seventrumpet.com/mercedes-be...e-light-reset/. Also from all of these either the call answer or call end button may be used. But thanks for the info.
