C350e Charging
Old Nov 12, 2017 | 03:19 PM
GerritKw's Avatar
C350e
Is this repeatable? The air-conditioning could at least have some influence, but not as much as the heating does.
I presume you are driving in a relaxed way. The driving style is a huge influencer on the range.
You could go to the garage and let them check the battery.
Old Nov 12, 2017 | 09:22 PM
JIMSHANN's Avatar
C350e with Comand, Vision Package and seat package, 2017 Mini Cooper S 7
Originally Posted by aaron ong
i have worst! 100% show 18km, real around 10km..any solutions?
I believe MB should offer an explanation as to what the system does and how it works.
After a year of owning a C350e I have come to the conclusion that the mileage shown, at "Full Charge" is the best you can expect based on the previous day's operation. i.e. it expects you to drive under the same conditions as previous.
If I have driven very carefully, the previous day it shows a higher potential mileage. If I have driven "furiously" then it shows much less.
I think it does not take into account the use of aircon and lights etc.
The 31kms that MB claim has never been achieved. As with most people the "Full Charge" shows 21km and immediately drops as soon as I drive away.
Despite all of this, over 9,000kms I have achieved less than 7l/100kms (45MPG Imperial) and am quite happy with this.
I don't think anyone with a C250 would achieve that in normal driving and would certainly not have the acceleration and torque that the C350e gives.
Old Nov 12, 2017 | 10:04 PM
aaron ong's Avatar
C350e
Originally Posted by GerritKw
What was the outside temperature when you drive it?
Did you drive in Eco or Comfort mode?
Did you use the pre-conditioning function?
The heating of the car consumes a lot of energy. With a normal combustion engine the heating is fine with waste heat of the engine.
My electrical driving range varies a lot at some cases. today i had a cold day and i did 2 short trips of 4 km. It had to heat the car twice. I was at 30% when i got home.
The temperature of the batteries have a big influence also. I therefore try to charge the car before i leave. The temperature is a bit higher then because of the charging. All tiny bits help.
yep. I can understand full charge show 17km-21km less value, i can not accept is only 50% achieved from already est. Less value! Seem nobody have idea, been to dealer same no answer.. where the car giving ard 10km full charge.. i accept if full charge show me 10km.. but it show again 18km-21km, ..
Old Nov 13, 2017 | 06:11 AM
JIMSHANN's Avatar
You seem to be doing a lot of complaining, but, you haven't mentioned what your overall fuel consumption is. Remember the car charges when you brake, or, go downhill.
Switch the car to the mode where you can see where the energy is being distributed. You will see that it, also, charges as well as discharges.
In my mind it is the overall fuel usage that matters. As I said, I don't think a standard C250 would give the same economy if driven the same way. (it has the same engine, without the extra motor power and torque, hence poorer acceleration.)
Old Nov 13, 2017 | 04:13 PM
GerritKw's Avatar
C350e
I have a fuel economy of 6.5l/100km and i am driving approximately 200km a day. Sometimes i am able to charge twice. In weekends i drive a lot of short trips.
I am sure a regular C250 isn't able to do this under the same conditions.
Old Nov 15, 2017 | 02:38 PM
Mbracer26's Avatar
Past 03 SL500,03 C240, 07 E350, 07 ML350, 10 ML350,11&14 E350 X2 2017 E300, 2017 C350e & 2000 S500
Does your gas pedal feel sticky or spongy when you press down on it?
Old Nov 15, 2017 | 08:50 PM
  #32
JIMSHANN's Avatar
Mine feels perfectly normal.
Old Nov 16, 2017 | 12:10 AM
  #33
GerritKw's Avatar
C350e
The gas pedal is giving haptic feedback.
When you drive in pure electrical mode it has a pressure point just before it wants to switch on the combustion engine. This helps you to stay in electrical mode.
Secondly when driving in Eco mode it gives a short vibration in the pedal (feels like the car is pushing the pedal a bit back) to indicate that you are approaching a car in front of you and that you can let the car coasting by taking your foot of the pedal.
Maybe that is what you are experiencing.
Old Nov 17, 2017 | 02:05 PM
  #34
Mbracer26's Avatar
Thank you for that explanation, but I know what the heptic feedback is. With even the car being off, when you press down on the pedal it doesn't feel smooth, its like not lubricated and feels spongy and sticky. reported it on the service and they said its operating as normally and even said it could have been due to the check engine light issue. Not even related.
Old May 21, 2018 | 06:44 PM
  #35
tralalak's Avatar
C350e
Originally Posted by JIMSHANN
My C350e will only charge up to 22kms charge.
I thought it was supposed to go to 31kms.
This means I am losing out on 30% of its electrical capacity.
Has anyone else had these problems?
Yes! I think MB lowered the charge limit of the battery for whatever reason. In 2015 when I got the car, I could easily do 29 km. Today, with exactly the same configuration and external conditions, I do 21 km. The change was sudden. The charge cycle takes 5.0 kWh from the wall. There is 10% charge left in the battery always, but even then, the 5.0 kWh from the socket can never reach (efficiency around 85%) the claimed 6.2 kWh capacity.
The car was doing great the first year. Then it changed to the same state as all of you observe as well. I think that MB is doing some **** behind our backs.
Old Aug 24, 2018 | 09:30 PM
  #36
Bent87's Avatar
C350e
I have never got more than 22km on my C350e in summer and 15 in winter. This is in Norway. -10C to 5C in winter and 10C to 28C in summer.
My record for fuleage is 4L/100km, but have around 6L/100km in 60h. Have done some upgrading in garage so not charged is that much actual.
But ye.... disepointed about what said and what is proven by battery kms!
Need to say that I am relay happy with the C350e in all other ways!
Old Jul 18, 2019 | 04:08 PM
  #37
Garyfbne's Avatar
C350e
back to the question
Dear Jim Shann
Your question was very clear and either not read / taken on tangents.by soem , not all
I am in BNE, and just got mt C350e 3 weeks ago - and have the same issue . Mind you mine was a 2018 demonstrator. thats 8 months old
dealer failed miserably in pre delivery - reset nothing - phones on BT, "home' on map, let alone gear change style history and whatever drives the Hybrid klm range
A full charge - 100% on one screen = 20 to 24klm. and that drops by 2 klm within 500 metres.. In the end 14klm of careful driving
different chargers make no difference
Dealers clearly make up stories that sound possible, but not based on any actual manual or facts ( when put to the test their explanation turns to water)
I am familiar with battery warranties for home systems - LG Chem Tesla etc etc. So I have been asking for the exact terms and testing procedure for the MB Battery - only to be met with a wall of "I don't know" or " we will see at the time"
I haven't given up on this.
So perhaps lets get in touch - an AU C350e group to compare notes as warranties come into effect? Esp as AU consumer law is different.
regards
Gary
Old Jul 18, 2019 | 04:14 PM
  #38
Garyfbne's Avatar
C350e
Im not a chemical or electrical engineer, but i work with them and are familiar with house batteries that you might add to a solar system.
The same chemistry in you mobile phone lasts a year or maybe 2.. But in a 10kwh home battery closer to 10.years. How / why ?
Im told its because the home battery manages its charges, it wont go down to zero - maybe 10% ( which is what I see on my C350e) and I think they also dont charge to 100% either
SO - perhaps software is severely limiting our range so that battery life expectancy is increased..
I assume that the battery capacity issue you report above started after a software upgrade?
Gary
Old Jul 19, 2019 | 07:43 PM
  #39
dwpc's Avatar
2017 C300 Cab 4Matic
Originally Posted by Shadwell
Go to the dealer.......
if they don't know it's their responsibility to find out...
Agree. The dealer should have the ability to both fully charge the hybrid battery and to measure that charge. A well-engineered battery should not lose significant capacity at 30C;a common temp in most markets.
