auxillary battery malfunction
My vehicle was 2 weeks out of warranty when I got the aux battery malfunction, haven’t got a quote from the dealer service dept yet but a local parts supplier wants $500 Aust + tax just for the component. Parts.com have it for $117 US but they don’t accept foreign credit cards or ship overseas.
It seems to have absolutely no affect on the operation of the vehicle except for the annoying warning message, does anyone know what this component actually does?
Part number 205-905-34-14-80
Service ticket says: aux battery has excessive resistance
code B1F4500
Test drove car. Performed Short Test. Removed pass side lower dash panel. Replaced aux battery. Cleared code.
So far so good.
code B1F4500
So far so good.
Yes you can get that part that remanufactured and the sellers of remanufactured parts will of course list by the appropriate part number but will say remanufactured. I am not aware of Mercedes having using/making refurbished parts and having special refurbished part numbers designating them. If you do a search on that part number you will see some listings saying OEM while others will state remanufactured or refurbished.
Would like to know with evidence that I am wrong and as I will go back to the dealer if you are correct!
Dealer replaced the Capacitor under warranty, today.
Part number 205-905-34-14-80 - Reman Voltage Conv. Service ticket says: Code present for buffer battery has a malfunction. Removed and replaced Capacitor (54-1183)
Given that there are multiple part numbers available for the W205 voltage regulator, does anyone know or have an opinion on which one is the best to use?
I did make a post a thread for my aux battery malfunction but no takers...even after I replaced it with a genuine aux battery the sign remains. Sorry and thank you!
did your stop start function ever start working again ?
Since fitting a remanufactured voltage converter my stop start has not worked over the Australian winter and I thought that maybe it’s just because the battery was low, but the other morning it started working again for a short time during a foggy dark morning with all the lights and wipers going so now I’m not so sure about the low battery voltage theory. I don’t miss the engine stopping as such but I also don’t like the thought that the system still has a malfunction
Regards
Greg
https://mbworld.org/forums/gl-class-x164-77/
EDIT: My apologies, I noticed you posted on the X164 forum earlier. Good luck with your search.
Try this:
First models were shipped with a voltage converter with part no. A 205 440 00 73. Such model has been replaced by a new part no. A2059052809.
I got mine changed less than a week ago. For those interested in what happens to your voltage converter there you go:
Someone help?
I would take out the voltage converter anyway and inspect it. Any bulging or leaking from the large cylindrical components (the capacitors) and it has definitely failed or is about to.
Capacitors are like batteries but are capable of producing much higher currents. It makes sense in a stop-start system as it will enable the starter motor to start the engine much easier without it becoming sluggish as the main battery starts to age. It also won't wear out the main battery as much. They don't store as much charge for their physical size though so without a large main battery or an auxiliary battery you wont get as many stop-starts before the system is disabled to let the main battery charge up.
I wouldn't be surprised if the aux battery is only found in models with larger engines. The higher starting currents would require a bigger battery and at some point space and weight requirements mean two batteries are a better option.
I went ahead and did it in about 35 min. the steps are:
1. Remove the cover under the glove compartment, this is a single screw and 2 clips
2. There are 2 cables attached to the cover (bulbs) so you have to disconnect both cables.
3. Pull back the carpet (carefully), it will be hard but the foam behind the carpet can be twisted without any issues
4. there will be a plastic cover with 3 nuts, you have to take them out and remove the plastic cover. You will see the voltage converter right there, which will be attached to the metal piece by a clip and a screw. Carefully remove the nut (Carefully and slowly). and just unplug the converter and replace with the new one and follow the same procedure in reverse.
Be careful with the tools as there are many DC cables under that carpet, so you can easily create a mess if you are not pretty careful.
I did not take any pictures with the details, but it is the same as the one posted earlier here
If you have any questions on this particular one just let me know
Regards
However, there were two fuse locations which I checked each and every fuse; located in engine bay and under passenger seat which is where the main & aux battery is loacted-- all fuses worked. Still in search of that darn capacitor on this x164.
