Disassembly of the Instrument Cluster
Old Feb 9, 2017 | 02:52 PM
2007 E Wagon's Avatar
E Class Wagon
Hello,
Does anyone know how to disassemble the instrument cluster on the W205? Please advise. Thank you for all of your assistance.
Greg
Old Feb 9, 2017 | 04:58 PM
DBOC205's Avatar
W205 C250BT
You mean to take the cluster out of the dash or how to take the whole cluster apart? .. what are you trying to fix exactly?
Old Feb 9, 2017 | 05:08 PM
Shadwell's Avatar
C300 S205 AMG, GLA 45 AMG
Extend steering column out full and down full.
Lock steering column in place.
Unclip plastic collar shroud at the base of the steering column top side and pull toward you at the base of the dash binnacle, put to one side.
two torx bolts visible at base of binnacle, unscrew and retain.
pull binnacle forward gently and angle the top edge forward (should be hard up against rear of steering wheel.
Un hook wire harness retaining loop.
Undo actual wire harness connector from rear of binnacle.
Manipulate binnacle rotating and sideways to clear the back of the steering wheel.
CAUTION not to gouge the dash front edge with the rear of the binnacle (masking tape this face at start if you are worried.).
Reverse for install.
Old Feb 10, 2017 | 04:42 PM
huyuci's Avatar
c300
Originally Posted by 2007 E Wagon
Hello,
Greg
Damn. And I thought I have been brave (aka crazy).
Old Feb 13, 2017 | 09:48 AM
E Class Wagon
Has anyone used something from this company?
http://www.heiler-tachodesign.de/Spe...h#.WKHG8lUrIkI
You can get the AMG Style cluster covers.
Let me know.
Greg
Old Feb 13, 2017 | 08:26 PM
B2FiNiTY's Avatar
'16 GLC300
Looks like you will need to take the needles off to install those. Not worth the risk since you might to recalibrate them. Unless benz clusters are self calibrating.
