Turning off Eco Start/Stop
Even when I go into agility select settings and have it turned OFF for every single one of my agility modes, it still turns on when I stop the car. Only sports+ does it have it off (but I think thats standard).
What am I doing wrong?
There's a bit parameter in the engine ECU which allows configuration to remember the agility drive mode. It's either a) remembered for 4 hours after engine off, b)default back to comfort after each ignition cycled, or c)to remember permanently. The setting is market/region dependent and can only be adjusted with special software tools (e.g. Vediamo). In the US market the setting is for the ECU to default back to comfort.
Engine ECU is locked (protected by a key algorithm) by the way, so even if you have a mux and Vediamo AND know what you're doing, then it's still not straight forward. There are some after market add-ons that disable the eco/ start stop (including from Brabus) but all come at added cost. Best to learn just to keep pressing that button to turn off.
