Weistec ECU Tune - C450
Hello,
I just noticed on the Weistec website that there's an option for an ECU tune. They don't list any numbers or price, but when I called they said it will be out in a month or two.
My question is, do I go with the OE Tune or wait it out for the Weistec Tune? What's everyone's thoughts on these two companies??
Thanks in advance....
No price or dyno numbers. I guess my question is, what company do you think is better to go with? I know that Weistec has done a lot of C63's and E63's with great results.
First off - I'm second to none when it comes to 450/43 tune research (up until January when I purchased mine).
Now, Weistec makes GREAT downpipes. Mine are amazing and it was and still is shocking to me that a company would offer such a quality part(s) for a german car brand at such a great price.
BUT, out of all the research that I conducted, one thing was agreed upon by everyone, and that is only buy hardware through Weistec. A lot of horror stories in regards to their software for previous generations and models. Perhaps that has changed since, but I wouldn't risk it unless their headquarters is down the block from your house.
As far as what software you should go with, I'd say it depends on your location and what you want. IMO, you have 3 choices. BMS, OE-Tuning, & AMR.
BMS - If you just want a piggy-back and don't want to go full tune.
OE/AMR - If you want a full tune. If one company is MUCH closer to you, then I would lean towards that for simplicity down the road in regards to shipping the ECU back and forth (you may have to do this more than once).
Final thoughts:
-I suggest going full tune. If you're a red-blooded-mod bug bitten-american like myself, you'll always want more; and with a full tune, you'll know that that is pretty much the furthest you can go at this point. Until they develop a turbo upgrade.
-Both of these companies make similar power @ stage 2 (tune+DPs). But if you're not going to put DPs in, then AMR makes a decent amount more power @ stage 1.
Happy modding
Final thoughts:
Happy modding
Final thoughts:
Happy modding
Final thoughts:
Happy modding
I currently have a stage 2 tune with Weistec downpipes. It's produces ok numbers, but the company that did the tune can't get rid of the CEL light. Because of this, I'm losing a lot of the crackle and exhaust pops.
I live in Canada, so either company works as it has to get sent over the border regardless.....
I'm leaning towards the OE tune but not sure of the stage 2 numbers. Has anyone put their car on a dyno with our setup?? I'm also kicking myself as I didn't take adavatange of the Black Friday sale they had on!!
Thanks,
Well good grief. That information would have been helpful before I typed all of that out
put that info in your sig or something so people know what's going on.
I have seen a lot of tuning options around including BMS, OE, AMR, Dinan, Renntech, Vivid, and Kleeman. Am I correct that the primary piggyback options are BMS, Dinan, Vivid and Kleeman?
I have seen discussion of some of the tuning options eliminating or greatly reducing the exhaust crackle which I definitely don't want to do. Of the piggyback options, are any particularly good about not messing with the crackle or particularly bad about reducing it?
The BMS and Dinan are significantly cheaper than Vivid and Kleeman and the gains appear to be in the same ballpark. That being the case, is there any reason not to go with BMS or Dinan? And any thoughts on how those two compare?
I've seen on the Weistec website that they will have a tune within a month or two. At the end of the day, I wanted to know which company has the best reputation with regards to tuning Mercedes Benz cars....
Thanks!!
Very interested to hear more of your well researched thoughts (or anyone else's) as I am at the beginning stages of evaluating tuning options. So piggybacks are self-installed by connecting to sensors while ecu flashes require shipping the ecu back forth, correct? I know there's a chance I ultimately reverse course, but I want to try a self-installed option to start (that doesn't require shipping ECU).
I currently have a stage 2 tune on my C450 with Weistec downpipes. The tune was done in Canada but the tuner can't get rid of the CEL light, and I lost most of the crackle and exhaust pops. Now I'm considering sending my ECU to another company (OE or Weistec).
Thanks!!
Thanks!!
the Dinan is just fine for a modest performance bump at a great price. And if you want a super easy install and removal the Dinan unit is the way to go. It does what it says it will do, certainly a full flash will yield bigger gains, but for $300 bucks the Dinan unit is pretty decent
