Considering adding a thing or two, couple of questions?
Ventilated seats, never had any experience with it, so what's yours? It's kinda pricy so I want to know if it's worth it. We got 6 months of winter and those really hot days come rarely.
Panoramic roof, never had that one either, so is it a gimmick or does it have a cause and something you benefit from? Even more pricy. And it can't generate more wind noise if I want to consider it.
Felt like I have been quiet for a couple of days so 😉
With regards to the pano roof, I don't have the wind noise but it creaks and sqeeks like crazy. I've had it back to the dealer once and it helped some. It's going back again. However, I think it makes the car look better and easier to sell. I would think you would get some of the money back on resale.
Ventilated seats are essentially two small fans in the seat back that draws air from the surface of the seat back away from the occupant. On hot days when you get in the car with a little perspiration on your back it'll draw it off and dry you out quickly. There's a "cooling" sensation but it's not dramatic. Nowhere near as obvious as the heaters, which use actual electric heating elements.
That said, a Mercedes really is greater than the sum of its parts. You will never regret loading one up. Saving a grand here or there doesn't have a huge effect on payment but can diminish your enjoyment of the ownership experience quite a bit.
My 2012 optima sx (i know, kia and mercedes are different) had ventilated seats and I loved them during the spring, summer and fall. If you have your ac running just in the upper area, you're not really gonna get the full potential out of those ventilated seats but when you have your ac on towards the foot area as well, the ventilated seats get that ac air as well and that's what helps the best. So in the long run, I'd say it's worth it. And I'm also personally a big fan of pano roof as well.
As for the ventilated seats, I feel they make a big difference in getting rid of the natural heat that traps between your body and the seat even if it is just air down in from the rest of the car.
Ventilated seats, though it don`t add any cold air to the seat, they will vent out some of the heat that occur while resting a back in a black leather seat on a warm summers day
As for the pano roof, well that's a different story. My old 2015 C300 had it, and my current C450 has it, and I couldn't imagine my car without it. I love how it can just vent (tilting up the back) or how large the opening is when it's opened all the way...not too much wind noise with it open either. My rear passengers also like the extra light they get in back as well.
No creaking issues at all with either pano roof.
Under rear bench, all doors centre console and the dash binnacle and added dynamat, high and low density foam in all apertures, felt tape touching faces, lubricated mating surfaces, installed missing fixings and tightened those which had eased or been incomplete fitted, and removed two extra fastener which had been dropped into the vehicle during assembly...
i also corrected thevfactory orange orange peel by wet sanding the car and polishing back to Jewel and ceramic coated, coated the wheels, trims and b pillars...
fitted a racechip ultimate, magnaflow exhaust, c43 exhaust tips and painted the diffuser trim gloss black.... and painted the callipers metallic silver, and the rotors zinc halved to look factory fresh....
iu sed the dealer to.....
Fix the; multitude of failed LED's, software glitches, failed vision system camera, failed trim pieces, broken pieces as fitted from factory in the trunk, corrected the wheel alignmnent, and repaired the wheels their alignment equipment damaged ....
and at the next service will have the leaking steering rack replaced under warranty ......
so yeah a bits been done...
I also have the ventilated seats. They do not cool the seats, but just blow air through the seat perforations. There is a noticeable cooling effect, but it's not dramatic.
