Low Volume from Iphone 7
Old May 14, 2017 | 02:55 PM
Chef Ray's Avatar
2022 AMG GLE 53 Coupe
Exclamation Low Volume from Iphone 7
Hello everyone,
I have a volume issue that I'm hoping someone in here has a fix.
I have an iPhone 7 plus and seems like lately (maybe after last update) when ever I play music from my iPhones music library via bluetooth or connected by USB the volume is very low. So low that when I switch to radio it is a huge difference. I've searched in this forum and others but can not find a fix that will work. I tried many different things including reseting the phone and still not fixed.
I connected my iPhone to my wife's car (Acura MDX) and it works perfect in her car.
Any help would greatly be appreciated.
Old May 14, 2017 | 02:59 PM
Mike5215's Avatar
2016 C300
There's a volume boost setting for BT. On COMAND while in the BT Audio screen select Options from the bottom menu. That might help. When you reset the phone you did a hard reset (hold down both Home button and Lock button until the device reboots and the white screen with black logo appears)?
Old May 14, 2017 | 08:11 PM
Chef Ray's Avatar
Thank you so much that helped plus i had sound checked on in iPhone settings so I unchecked that and I also played with the EQ settings in COMMAND.
I now consider this matter resolved.
Old May 15, 2017 | 10:10 AM
mersoclk's Avatar
mercedes benz c180 1.8 180hp 96.000
Did hello improve?
Old May 15, 2017 | 07:13 PM
Chef Ray's Avatar
If by "hello" you mean sound level, yes it helped now volume from iphone matches volume from radio.
