AerowerkZ TriColor Ambient LED Lighting Kit for W205 C-Class Sedans
Former Vendor of MBWorld
AerowerkZ Motorsport is proud to announce TriColor ambient LED lighting kit for W205 C-Class sedans.
![AerowerkZ TriColor Ambient LED Lighting Kit for W205 C-Class Sedans-ptmcrqf.jpg](https://mbworld.org/forums/attachments/c-class-w205/442222d1683250501t-aerowerkz-tricolor-ambient-led-lighting-kit-w205-c-class-sedans-ptmcrqf.jpg)
Installed on GLC300 Coupe
![AerowerkZ TriColor Ambient LED Lighting Kit for W205 C-Class Sedans-itdvhug.jpg](https://mbworld.org/forums/attachments/c-class-w205/442223d1683250501t-aerowerkz-tricolor-ambient-led-lighting-kit-w205-c-class-sedans-itdvhug.jpg)
![AerowerkZ TriColor Ambient LED Lighting Kit for W205 C-Class Sedans-6kd7v69.jpg](https://mbworld.org/forums/attachments/c-class-w205/442224d1683250501t-aerowerkz-tricolor-ambient-led-lighting-kit-w205-c-class-sedans-6kd7v69.jpg)
Installation photos
![AerowerkZ TriColor Ambient LED Lighting Kit for W205 C-Class Sedans-tz7crxe.jpg](https://mbworld.org/forums/attachments/c-class-w205/442225d1683250501t-aerowerkz-tricolor-ambient-led-lighting-kit-w205-c-class-sedans-tz7crxe.jpg)
![AerowerkZ TriColor Ambient LED Lighting Kit for W205 C-Class Sedans-uk5ry38.jpg](https://mbworld.org/forums/attachments/c-class-w205/442226d1683250501t-aerowerkz-tricolor-ambient-led-lighting-kit-w205-c-class-sedans-uk5ry38.jpg)
Center console install on W205 C300 sedan
![AerowerkZ TriColor Ambient LED Lighting Kit for W205 C-Class Sedans-faw5g5r.jpg](https://mbworld.org/forums/attachments/c-class-w205/442227d1683250501t-aerowerkz-tricolor-ambient-led-lighting-kit-w205-c-class-sedans-faw5g5r.jpg)
Front door install on W205 C300 sedan
![AerowerkZ TriColor Ambient LED Lighting Kit for W205 C-Class Sedans-qphyhtg.jpg](https://mbworld.org/forums/attachments/c-class-w205/442228d1683250501t-aerowerkz-tricolor-ambient-led-lighting-kit-w205-c-class-sedans-qphyhtg.jpg)
Rear door install on W205 C300 sedan
![AerowerkZ TriColor Ambient LED Lighting Kit for W205 C-Class Sedans-dukxucd.jpg](https://mbworld.org/forums/attachments/c-class-w205/442229d1683250501t-aerowerkz-tricolor-ambient-led-lighting-kit-w205-c-class-sedans-dukxucd.jpg)
Settings on W205 C300 sedan
![AerowerkZ TriColor Ambient LED Lighting Kit for W205 C-Class Sedans-hwbg4f9.jpg](https://mbworld.org/forums/attachments/c-class-w205/442230d1683250501t-aerowerkz-tricolor-ambient-led-lighting-kit-w205-c-class-sedans-hwbg4f9.jpg)
Rear door installed on W205 C300 sedan
Install Guide (PDF)
- Change from 3 available LED colors just like factory option
- Adjust brightness levels just like factory option
- Price: $499 for sedans (LEDs on center console and four doors)
- FREE shipping to continental US for forum members
- Compatible with Linden or Burl Walnut wood trims only
- No cutting of factory wiring harness
- Comes with 1-year warranty
- Professional installation is strongly recommended
- Version coding is required after installation (optional OBD2 programming adapter also available)
- Footwell LEDs not available
Installation photos
Install Guide (PDF)
When we installed on natural grain ash wood, the door trims' shape were different.
We initially thought it will work on all sedans, but when we tried to install it on sedan with natural grain black ash wood, we realized the shape was different (even though Mercedes part numbers are identical). Because the customer still wanted LEDs installed, we had to make a lot of modifications to make it fit. We plan to make correct parts for sedans with natural grain wood trims in the future.
Sounds a bit strange. I installed Ambient Lighting on my C250. Front door trims I used dismantled from walnut inserts, and they fit perfectly. Rear ones I had to buy. A205 730 76 22, A205 730 75 22.
AerowerkZ (06-09-2017)
You stated
"Version coding required (optional OBD2 programming adapter also available)"
Does this mean yall loan out your adapter for a cost?
Do you know if this install will cause any part of my factory 4 yr/50K miles and my cpo warranty to become invalid with this install and hardware?
You stated
Although we can't guarantee it, you shouldn't have any issues with warranty since our product installs at factory locations without cutting any of factory wires and requires programming, just like factory option.
