separate amp switched feed
Old May 31, 2017 | 05:16 AM
MYC250AMG's Avatar
2016 C250 AMG Line Premium
HI. Where have people taken an remote switched feed to switch on an external amp? I used to use the power antenna switched output from the ISO connector on the Head Unit but this didnt seem to work on Audio 20
Old May 31, 2017 | 06:10 AM
ManiacGT's Avatar
BMW e89 Z4 sDrive 35i & MB S205 C200 AMG Premium Plus
Can't you take a switched power feed from the fuse box in the cabin? The fuse box has a layout showing the respective functions.
Old May 31, 2017 | 08:39 AM
Mike5215's Avatar
2016 C300
I think he's looking for somewhere to connect a remote sensing lead to trigger the amp to wake up when the audio system is on.
If all else fails connect the sensing lead directly back to the + side of the amp itself. Then put the amp itself on a switched power source to avoid battery drain.
