2016 C300 4matic Wheel Fitment Questions
OEM set up is:
Front: 225/45/18 18x7.5 ET44
Rear: 245/40/18 18x8.5 ET49
Will this new setup perform well and not rub?
Front:245/40/18 18x8 ET 38
Rear: 265/35/18 18x9 ET 39
I've done all the wheel tire calculators and:
Front: .6" further out and .2" further in
Rear: .7" further out and the same clearance inner
Does the computer look for a certain ratio for tire revolutions between front and rear and will the above cause an issue? The OEM set up has a 7 revolutions per mile difference between front and rear and the new set up has a 12 revolutions per mile difference.
I will need to change the 315MHz sensors currently in the new set to 433MHz sensors for the 2016. So before doing this deal input on the fitment from experienced benz owners is greatly appreciated.
Thanks.
I'd just transfer your TPMS over to the new wheels. They're integrated into the valve stems.
Yes it seems aggressive to me too - mine is the 4 matic, preferred the RWD but none were available when I was shopping.
What tire size are you running with your set up?
Thanks again!
On a 4Matic you'll want to keep the difference in rolling diameter between front and rear axles at 3% or less. Www.1010tire.com has a nice calculator for sizing tires.
