best tire fitment of 8.5j wheel x4
i have installed 245/35/19 x 4 with 8.5j Rays G25 19 inch wheel, I feel the handling is not as sharp as original set up, but of course, the wheel is much lighter than before. about 9kg per wheel only.
Therefore i consider to change it to
225/40/19 Front, 245/35/19 R
or 235/35/19 F, 245/35/19 R?? (may i know the tolerance of Front, rear circum difference)
Or any other suggestion, i want to improve our handling for this changes. (not used to 245 width tire on front)
Also for 225 to 8.5 J, may i know which brand of tyre with have a tire protector, so that it looks not so stretch... I had tried PSS before on our previous car 225 on 8.5j, any other suggestion too.
Thanks for comment.
Thanks for comment.
thanks for your help, i will try to bump up higher pressure on the rear or lessor pressure on the front, to see it can improve the handling or not. Or as it is square set up, 4 wheel need to be identical pressure.
