C400 Brakes?
My last car was a modified GTI w/rotors from AdamsRotors, EBC Yellow Stuff pads, and stainless braided lines. That car stopped on a dime.
Has anyone done any work to their brakes?
I did the brake modifications on it myself and can tell you that the difference from the OEM to the modified setup I described was worth every penny (especially when it wasn't even that great of a price difference). I'm not looking to go 'OEM and be happy', I want to make the brakes work as well as possible.
EBC makes yellow stuff front brakes, not sure about rears. I think the rotors are good for now.
Anyone know if there are braided lines for the C400?
Parts catalog shows the same rear brackets and calipers but a 320mm vs 300mm rotor diameter with a different pad to go with it.
Typically a larger rotor requires either a different caliper or bracket, hoping these have the extra 10mm of room to bolt up. Unless the hub/knuckle is different and thats where the spacing is coming from...
Should specify that i dont have the airmatic and cant find the non-airmatic knuckle to compare parts #'s on.
