Navigation SD eBay?
Old Sep 1, 2017 | 05:44 PM
SaltyBones's Avatar
2017 C300
Navigation SD eBay?
There's plenty of navigation SD cards on eBay for a fraction of the price the dealer was quoting me when I bought the car. I got it in the mail and it seems to work. Are these legit, or did somebody just buy a card and start bootlegging copies?
Old Sep 2, 2017 | 10:31 PM
fabbrisd1's Avatar
A gaggle of MB's
Depends... see my comments below
I have seen eBay copies that certainly look and work like genuine OE cards... I have bought and used about 12-14 so far.. US eBay source now like $120 each.. come in paper sleeve packaging with inner anti-static envelope - all marked with genuine OR #'s.
Here in the US - the cards delivered to dealers are packaged in a DVD clam shell..
Please see my post this forum on "updating" the System... and "updating Map" (if available) with SD card reader.. follow my steps to prevent frustration
Old Apr 8, 2022 | 12:18 PM
RWagz's Avatar
2022 X213 E 450 Wagon
I just went through figuring this all out and making it work. I found a lot of helpful instructions with dead links. To make this helpful long-term I'm avoiding ephemeral links and torrent files. I'll just share enough information to find it on your own in your own timeline.
Here's how I did it safely:
  • Since I got everything from torrents, I used virtualbox VMs without ever executing anything on my host PC
  • None of my VMs were given any network access.
  • All data to/from the VM was moved over either a USB drive or ISOs mounted in a virtual DVD drive
If you want to be really safe I would create a VM to download the torrents and search web sites for torrent links. Those are some seedy sites.
Sources:
  • Torrent "WIS" 19.62GiB - VM disk image that happens to contain keygen
    • The keygen program is difficult to find. I ended up downloading this russian virtualbox VM named "WIS" that happened to have that keygen on it.
    • I tried finding other sources for keygen. They're locked up behind websites where you pay $20-30 to get an account. I think these sites survive takedown requests because they're behind a paywall.
    • I copied the keygen to a flash drive before discarding the VM.
  • Torrent "EPC 2018-11" - 29.86GiB
    • Chosen because it looks like this went to cloud/online hosting and my old 2010 is well-covered in this older version
    • Contains five ISOs
  • Torrent "WIS 2018-11" - 15.17 GiB
    • Contains two ISOs
  • Windows 7 Professional SP1 - many sources
    • For a fresh English installation of windows because that original WIS was in russian.
    • Search for a product key online and try some until they work
  • Internet howtos - print to pdf and transfer via the flash drive
Lessons learned:
  • Create a new win7 VM with 4G RAM, a single processor, and a single 64GB dynamic volume (with ended up being just under 55GB after installation)
  • Installation is rather complicated compared to modern applications.
  • Installation tips
    • Copy the keygen software to the VM via the USB drive
    • Mount the ISOs as virtual DVDs. The software makes you "install" each disc multiple times because it ensures that you the complete disc set prior to installation
    • The ISO names A1, A2, A3, A4 do not match up with the name the installation program uses when asking for the disc. Just use them in order.
    • After installation tweak the um_cfg.xml configuration file to prevent "error 462" (covered in the blog post linked in the previous line)
      • <PARAMETER name=”tokenActiveMinutesAfterStart”>-1</PARAMETER>
      • <PARAMETER name=”tokenActiveMinutesAfterReinitialization”>-1</PARAMETER>
    • Print-to-pdf the installation instructions and keep a copy on the VM - handy to have there
    • Make the admin password the same as your luggage - 12345 - and create a text document on the desktop with this and any other relevant login info.
