Flooded needs help
Old Sep 6, 2017 | 08:35 PM
2002328's Avatar
W202 C280
Flooded needs help
My C250 was flooded due to a devastated typhoon, up to the height of the seat sitting cushion was flooded with water. Now I am looking for used repaired parts. I want to know the names of electronic devices those are located on the floor of the left hand side of the front seat, mine is RHD version.
Thanks.
Old Sep 6, 2017 | 10:12 PM
Kartergreg's Avatar
2013 ML350 Bluetec, 2016 C3, 2020 Lincoln Aviator
Save yourself grief and just get rid of it.
Old Sep 7, 2017 | 01:40 PM
Mikey53's Avatar
Veteran: Air Force
2016 C300 4Matic traded in for a 2022 E450 Coupe
+ Infinity
Old Sep 7, 2017 | 04:21 PM
Gungaslow's Avatar
2017 C43 sedan
Sell it to an unsuspecting old lady for above book value.. then run!!!
Old Sep 8, 2017 | 07:17 PM
dwpc's Avatar
2017 C300 Cab 4Matic
I get the idea that you're not in the US, so may not have the same access to insurance and must try to salvage the car yourself. You should look a factory workshop or repair manual online that can be downloaded as pdfs and provide all the parts and wiring info you need. A flood car is likely to be an ongoing nightmare unless you replace all the electronics and wiring that were affected. Very costly in cars with so much electronics, especially if you're not a technician.
Old Sep 27, 2017 | 10:55 AM
2002328's Avatar
W202 C280
Thanks your advice. I had successfully found some parts and am looking for the wiring loom inside the passenger compartment. The connectors of the original wire are not reliable anymore. Any hints of where to find it. I went through eBay but failed. I think the wire set itself does not cost a lot thus the dismantler shop will not pull it out for sale.
Old Sep 27, 2017 | 12:24 PM
BF3PDZ's Avatar
E class, C class
Thanks.
I am guessing you are from HK? Shouldn't your insurance cover damages like that as well?
Old Sep 27, 2017 | 08:56 PM
2002328's Avatar
W202 C280
Normally insurance doesn't cover lost due to typhoon. Considering the value of the car and the cost for repairing it, I decided to go. Of course, lots of follow ups to go. Anyone can help to recommend someone I can approached to find the wire set?
Old Oct 3, 2017 | 01:08 PM
Luton Driver's Avatar
C Class 200 sport petrol auto
Good luck, this guy had his C63 written off after just 2 months when a car splashed his car in heavy rain.
The incident
Old Jun 13, 2019 | 03:19 PM
boardboy330's Avatar
2000 ML320, 2005 E320 CDI
Wow, interesting thread as I just had my 2007 S550 AWD flooded today. Everything seems to work but the car won't start. Frustrating.
