Coolant Low
Old Oct 24, 2017 | 12:14 PM
Mxjet1's Avatar
new owner
Coolant Low
I got a Coolant low pop up the other day when i first started the car. I was taking my c450 in for its recall and had the dealer also check this out. The service writer and the receipt said the system was topped off and leaked check with no problems found.
Now the crux of the problem is I just had my 10k service only 5k miles ago and that was performed at a different dealer that this service call.
So one of two things has happened. Either the dealer didn't do the 10k check properly or I have a leak.
Since it was just checked today I would think that the dealer that i took it to for the 10k service is at fault.
Any input would be great.
Old Oct 24, 2017 | 01:15 PM
fabbrisd1's Avatar
A gaggle of MB's
Frankly - I would not worry about "leakage" unless you or the technician spot some fluid. Frankly -
The the new gen Mercedes Coolant Level Sensor systems are quite/quite "sensitive" - meaning 2-3 oz either way can cause a alert under/over.
Old Oct 24, 2017 | 02:05 PM
Mikey53's Avatar
Veteran: Air Force
2016 C300 4Matic traded in for a 2022 E450 Coupe
any significant temperature changes lately? Change in altitude? I wouldn’t worry about it unless the light comes on again or you notice wet spots under the car.
Old Oct 26, 2017 | 01:34 PM
l3it3r's Avatar
Veteran: Army
2015 W205 C400 4Matic
I had a 2017 C300 loaner that overheated on me within 5 minutes of leaving the dealer. They actually put on my file at my dealer 'No CLA loaners or car #4' haha
Anyway, I think it had a leak.
