2016 C300 Wheel and Tire
Hey guys and gals,
I'm sure you get this a lot but I would sure appreciate your help. Can you tell me if these specs of wheels would fit on my 2016 C300 sedan base package?Size :
19x8.5 (F) & 19x9.5 (R)
Bolt pattern :
5x112
Offset :
45mm (F) & 45mm (R)
Hub Bore :
66.6mm
Thank you!!!
Bolt pattern :
5x112
Offset :
45mm (F) & 45mm (R)
Hub Bore :
66.6mm
Thank you!!!
Hey guys and gals,
Bolt pattern :
5x112
Offset :
45mm (F) & 45mm (R)
Hub Bore :
66.6mm
Thank you!!!
Bolt pattern :
5x112
Offset :
45mm (F) & 45mm (R)
Hub Bore :
66.6mm
Thank you!!!
