Need some advice on these 20” rims and lowering?
Old Nov 5, 2017 | 01:24 PM
Killer w205's Avatar
W205 2014 saloon
Hi
I have just purchased my first ever Mercedes Benz yesterday. It’s a c220d sport premium , plenty of toys.
i will be changing bumpers, lowering, de chroming etc etc.
I would like some advice on some wheels.
8.5x20 ET 25 fronts
10x20 Et42 Read
5x112
CB72.6
will these wheels fit comfortable without running as I wanted to lower it also. 30-40mm maybe so the wheels are nicely sat in the arches with an aggressive stance.
any advice would be greatly appreciated
thanks
Old Nov 6, 2017 | 12:15 PM
W205 2014 saloon
Any one ?
Old Nov 7, 2017 | 05:01 PM
W205 2014 saloon
Up up?
any one ???
Old Nov 9, 2017 | 06:17 AM
Mr_marko77's Avatar
2017 C300
I think the fronts will be fine, but you might run into issues with the rear depending on how wide you go with the tires. Try going to a wheel shop and ask I feel they can test fit a few different sets.
Old Nov 10, 2017 | 06:25 AM
W205 2014 saloon
That’s the thing they are not from a wheel shop 😔 it’s a gamble but thought somebody might be able to tell me for definite?
yoy say issues with the rear? Would that be rubbing or poking out too much?
thanks
Old Nov 10, 2017 | 12:46 PM
killascrimp's Avatar
c400
LOOKS LIKE YOU HAVE THE CORRECT OFFSET NOTSURE ABOUT LOWERING BUT IT WILL DEFF BE TIGHT I THINK YOU SHOULD BE FINE, THE RIDE QUALITY ON RF PROB NOT BE THE MOST COMFORTABLE BUT IT SHOULD LOOK VERY NICE i AM GOING W 19' STAG
Old Nov 10, 2017 | 12:52 PM
W205 2014 saloon
Thanks for the swift response ^^^
ill take a punt and get em! 😁
will post pics,
going for the full murdered look , amg bumpers etc,
Old Nov 10, 2017 | 02:29 PM
c400
Me too I just ordered the emblems wheels soon
Trying to get a look similar to this .. so many choices w the new w205 aftermarket products....ttyl
Old Nov 10, 2017 | 04:28 PM
Mr_marko77's Avatar
2017 C300
The issue will be tire rubbing on the outside of the guards/wheel arch, especially if you get runflat tires and reduce the height by 30-40mm. You might need to reduce the tire width and end up with the stretched look like the drift boys go for. I tried a few different combos at a wheel shop and ended up staying with the 19" amg wheels with 255 35 19 tires. If you want to increase the camber on the rear you shouldn't have a problem.
Old Nov 11, 2017 | 02:08 PM
W205 2014 saloon
thanks for taking the time to reply!
damn wish I went for 19” option now and dropped it! 😔
not a huge fan of the stretched tyre look especially being my daily, need some comfort! Lol
wont be getting run flats so on that front I should be ok?
will the fronts be ok? I don’t mind SOME camber on the wheel but not massive?!
will putting 20” wheels and lowering really affect my ride?
Old Nov 11, 2017 | 03:22 PM
Mr_marko77's Avatar
2017 C300
You should be fine if you run a bit of camber in the rear and standard tires. The fronts should not have any issue at all.
The ride will be significantly firmer.
Old Nov 11, 2017 | 03:33 PM
W205 2014 saloon
what tyre sizes should I be looking at? I really don’t want to be running stretched tyres that’s all,
Old Nov 11, 2017 | 04:55 PM
Mr_marko77's Avatar
2017 C300
For comfort look at the tire size 295 35 20 but for the correct sizing and to keep the speedo accurate 285 30 20
