C250d with Command + iPhone via USB & Spotify Issues
Old Nov 19, 2017 | 12:50 PM
DangerMouseUK's Avatar
C250d AMG Line
Question C250d with Command + iPhone via USB & Spotify Issues
Hiya,
Has anyone else with a C-Class with the Command Online system using an iPhone via USB cable got patchy Spotify functionality.
If you skip too many songs it exits out of Spotify playback and starts playing your normal iPhone music back instead.
Has anyone else noticed this sort of erratic behaviour?
DM
Old Nov 19, 2017 | 01:47 PM
ManiacGT's Avatar
BMW e89 Z4 sDrive 35i & MB S205 C200 AMG Premium Plus
I use the same setup and don’t have an issue.
i do find usb behaves better than Bluetooth for song selection via the cluster.
Old Nov 19, 2017 | 01:59 PM
C250d AMG Line
You use Spotify on an iPhone running iOS 11.1.2 and have it hooked up via USB and playing via the media interface not Bluetooth?
mine is erratic playing over USB - if you skip too many songs it gets stuck and stops playing Spotify music and goes back to your stored music on the phone.
Old Nov 19, 2017 | 02:53 PM
ManiacGT's Avatar
Yes exact same setup and no issues.
Old Nov 20, 2017 | 09:27 PM
C250d AMG Line
Yeah I've noticed its only when I try to skip a certain amount of songs within Spotify quickly like 3/4 plus.
If I space out the skipping to one per 10 seconds or so, it doesn't do it.
Maybe the software in UK cars is slightly different? Anyone else having a problem with latest iOS and what I presume is an MY17 Command based W205.
Old Nov 29, 2017 | 11:28 AM
C250d AMG Line
Yeah tested it again and its still doing it via USB - if you skip 2/3 songs in quick succession using the jog dial or the skip forward on the trackpad whilst its connected as a media interface device over USB it will crap out and exit spotify and start playing your natively stored music in the music app.
Also it doesn't seem to be able to pull in spotify playlists at all - when its playing the songs it just says the track 1,2,3 etc and nothing else.
Can anyone else who uses an iPhone and Spotify and has the Command system just load up a playlist and skip a few songs in quick succession and see if it exits out of the spotify playback?
Old Nov 29, 2017 | 12:45 PM
alyshehata's Avatar
2016 C300 4MATIC
I have the same issue you are having. In fact, I couldn't even control volume some times when using Spotify, and so I switched to Apple Music. It works much better with the Audio 20 system. I do kind of miss spotify, but not being able to control the volume drove me mad.
Old Nov 29, 2017 | 06:26 PM
C250d AMG Line
My car was made half way through this year I think well no April of this year, wonder if there's a firmware update for the Command system that fixes these problems.
I've noticed iOS 11 has added a few problems into the mix as well with regards to USB audio - lets hope Apple fixes them by 11.2.
Old Dec 2, 2017 | 10:29 AM
C250d AMG Line
iOS 11.2 which was released today seems to have made things better (so far) reliability wise, seems to be jumping out of Spotify playlists less.
Old Jun 6, 2018 | 05:16 PM
lordzed's Avatar
W205
I'm facing the same issue with the latest iOS (Iphone SE 128 GB) and latest comand firmware.
Have you found any solution? (would less offline songs help?)
Old Jun 6, 2018 | 05:25 PM
alyshehata's Avatar
2016 C300 4MATIC
My solution was to switch to Apple Music. I don't like Apple Music much, but controlling it from the car is painless. I can see my current track list, choose which songs I want to play from the steering wheel, and search for songs pretty easily.
Old Jun 7, 2018 | 04:52 AM
lordzed's Avatar
W205
Thank you, I was hoping someone has figured it out in the meantime...
