Will switching out runflats for regular tires affect my warranty?
Old Jan 17, 2018 | 03:41 PM
Elbandito's Avatar
2015 c300
will it affect my warranty, and what sort of documentation would I need? And also are the tire pressure still the same recommended psi of 36 for the non-run flats, or are they different?
Old Jan 17, 2018 | 03:59 PM
PaulE550's Avatar
2015 E550 Coupe
Swapping out tires does NOT void your warranty. You just have to use non-run flats (regular tires) that are appropriate for your car. If you bought your car, it IS your car after all. If you leased your vehicle, then somewhere in your contract it may state you are probably expected to return the vehicle at the end of the lease with the original equipment configuration you received. So at the end of your lease, just put the run flats back on.
Old Jan 18, 2018 | 06:59 PM
sean1.8t's Avatar
c-fo-fiddy
Nah man, you can, within reason, run any tires you want. 4MATIC people have to run the correct sizes though as if you run a staggered setup and blow your center diff, Benz isn't going to cover that or anything else. But most shops won't even install such setups on AWD vehicles as they don't want to be liable.
Also, I always suggest to people on a lease to not put more than a few thousand miles on the OEM run-flats and to shelve them for when you turn the car back in. Reason being that run flats are expensive, perform terribly, ride even worse, and wear out extremely quick. So if you're going to have to buy tires, get some quality performance tires and save the crap ones for returning the car with.
Old Jan 19, 2018 | 03:20 PM
Mikey53's Avatar
Veteran: Air Force
2016 C300 4Matic traded in for a 2022 E450 Coupe
+1 I had the dealer swap out the OEM runflats for AS as part of the purchase deal.
Old Mar 5, 2018 | 07:43 PM
goldbee's Avatar
Porsche 997; Subaru STi; Mercedes C300 Wagon
Assuming the right size tires/wheels are swapped in, will swapping out the runflats and a different set of wheels trigger any warning message on the dash ? Do I need to reset anything ?
I assume there aren't any TPMS sensor in the factory wheels ?
Old Mar 5, 2018 | 08:16 PM
pdeacon's Avatar
E450 wagon, C43 AMG Cpe, GLE AMG 63S
There are TPMS sensors in the factory wheels. If you swap rims and don't use TPMS sensors you will get a dash warning light. If you are going through the effort of swapping wheels and tires you might as well go for the sensors and do the job completely.
Old Mar 26, 2018 | 10:10 PM
SidE2's Avatar
Veteran: Air Force
2019 E450 Coupe; 2019 E300 Sedan, 2019 Volvo XC90
Different sized tires w/4MATIC
I just replaced my Continental ProContact run flats with Continental ExtremeContact DWS06s (thought about Pilot Sport A/S3+s, but have had good luck with Extremes since before they introduced the DWs and DWSs, and they were about $20/tire less expensive than the Michelins). At any rate, the difference in handing, steering response, and ride quality vs. the run flats has been night and day. Even my wife noticed the smoother ride from the passenger seat .
At any rate, the DWS06s in the right size for the front (225/45ZR18) have an SL load range 91Y rating, which is apparently too low for this car. As a result, I bought my DWS06s in 235/45ZR18s (98Y XL) for the front and 255/40ZR18s (99Y XL) (vice 245/40s) for the rear. The diameters are 26.3" front/26.0" rear (vs. 26.0/25.7" for the 225/245 combination), therefore, I'd assume minimal effect on the center differential. The difference in the diameters, BTW, is approx 1.2%, so the speedo now runs 0.7 mph slow - not a big deal.
Am I making a good assumption that this modest size increase will not affect the center differential, or should I consider taking advantage of Tire Buyer's 45 day satisfaction return policy and trade them for Pilot Sport A/S 3+s in 225/245 instead?
