19 inch wheels help needed!
Old Feb 26, 2018 | 03:04 AM
David MJ Ko's Avatar
c200
Hey Guys
I want to ask you guys if it is quite easy to interchange from my 18 inch 5 spokes to 19 inch multispoke wheels as i managed to find some 2nd hand ones without doing any adjustments to the vehicle. Would it be a simple pluck out and in procedure? I finally managed to find some after looking for a long time as 19s are so expensive especially in the area im living in (Oceania).
Any feedback would be greatly appreciated
David
Old Feb 27, 2018 | 12:09 PM
Drew White's Avatar
W205 C300 Sport Iridium Silver RWD
Direct replacement, as long as they came off the same vehicle.
Old Mar 1, 2018 | 02:34 AM
Cosworth2000's Avatar
2022 E53 AMG
No problem. I have 18 winters and 19 summers
Old Mar 1, 2018 | 10:54 PM
Jack Olsen's Avatar
Overall diameter is the issue with ride height and the speedometer/odometer being correct. The diameter of the wheels is different than that. Generally speaking, the larger diameter wheels will take tires with shorter sidewalls, resulting in similar-or-identical overall diameters. You can check by plugging in the tire sizes to an online tire size calculator.
