Eibach Lowering
Old May 4, 2018 | 03:26 PM
redfar's Avatar
w205
Eibach Lowering
I bought a set of Eibach lowering coils.35 mm front and rear. but the car is not level,the front is 2cm lowered than the rear.
Do some one use a set of eibach on C class?on how is your car level?
with eibach springs
Old May 4, 2018 | 04:50 PM
RUNSGR8's Avatar
2017 C300 Coupe - Polar White/Saddle Brown MBTex
How long has it been since you got the springs installed? I remember when I put the Eibachs on my coupe last year, the rear took longer to settle down than the front. About 1 week to be exact. Even then, our cars are setup so that the front is lower to the ground than the rear.
This is my coupe now, after 1 full year on Eibachs:
Old May 4, 2018 | 04:56 PM
redfar's Avatar
w205
Thanks allot for your reply,
I installed them today,can you please check how much difference you have from the ground from the front to the rear
Old May 4, 2018 | 05:02 PM
RUNSGR8's Avatar
The fender clearance (top of the tire to bottom of inner fender gap) is the same from front to rear after lowering. I think what's giving you the impression of unevenness is the fact that our cars are naturally angled forwards from the factory. The body of the car sits higher in the rear than the front.
Old May 5, 2018 | 04:30 AM
redfar's Avatar
w205
Mine is not the same clearance I think some thing is wrong with the springs.I asked eibach about it.
Old May 5, 2018 | 09:47 AM
RUNSGR8's Avatar
Again, give your springs some time to settle down. The rear takes a bit longer than the front, presumably because there's less weight in the rear compared to the front where the engine sits directly over the wheels. The technician who installed my springs gave me the same advice, that the rear would settle within a week.
Are your wheels running against the fenders while over bumps it while turning? If not, you shouldn't worry. Keep in mind that you also have the Sport Package on your car, which means your car is lower to begin with. Eibach springs will bring that down even lower, compared to my car.
Old May 5, 2018 | 09:52 AM
redfar's Avatar
w205
there is no rubbing at the front.I hope it will be the same height because I don't like it higher at the rear.
Old May 9, 2018 | 01:54 AM
PieAitsch's Avatar
2018 GLC Coupe & 2019 C300 Station Wagon
Did you maybe order the wrong springs ? there are two different versions available from Eibach.
- One is for Gasoline 4 cylinders (axle load until 1030kg) and the other ones are for diesel and 6 cylinders (axle load until 1155kg)
