W205 fuse for Command system ?
Old Jul 23, 2018 | 10:57 PM
Dai's Avatar
Dai
C200(W205)
Question W205 fuse for Command system ?
My W205, C200 sports is facing black out of Command system display. LCD screen are completely black out , thus Navigation,Air conditioner setting,Music,TV and any setting are unavailable.
For command system reset , to unplug a fuse might be faster way, but I cannot find the particular fuse for command system in fuse diagram chart which is placed under rear trunk.
What I only see in chart is TV tuner fuse, but it's not supposed to be for Command system.
Does anyone know which fuse is for command system?
Thanks in advance
File Type: pdf
Old Jul 24, 2018 | 01:11 AM
cgw944's Avatar
2018 C300
I had a similar problem a few weeks ago, and I also thought it might be a fuse. But the explanation was even simpler. As I was parking, I raised my rear sunscreen, since it was a hot, sunny day. When I returned, COMAND was not working ant the screen mainly stayed off. It turned out that when I hit the button for the rear sunscreen, I also hit the button to turn COMAND off. Check the on/off button on the right side of the console to see if that fixes it.
Old Jul 24, 2018 | 06:42 PM
damianw's Avatar
W205 C200d AMG Line
Thanks in advance
Hi,
I found a website:
http://knigaproavto.ru/shemy/en/merc...e-diagram.html
There you can find all fuses. I found the one for Head Unit:
Hope this will help you.
Another option is to reset command: Hold the DVD eject button for 10 seconds to reset the system
Old Dec 28, 2020 | 05:17 PM
GLO's Avatar
GLO
W205 C250BT & R320cdi-L V251 (sold c220 cdi Elegance)
Was the fuse blown?
Old Dec 29, 2020 | 05:39 AM
shan16's Avatar
C250
322 is the comand system fuse on the left side kick panel
Old Apr 1, 2021 | 10:26 PM
GLO's Avatar
GLO
My 322 fuse was blown and I replaced it, but still have black screen.
How do you remove the MF1/1 fuse?
Old Aug 1, 2021 | 02:39 AM
GLO's Avatar
GLO
The MF1/1 was a mf to pull out but its intact.
fuse 322 was replaced and unit was working but command is black again.
anything else i should check?
Old Jul 29, 2024 | 02:28 PM
Wut's Avatar
Wut
W205
Thx
many many thank you ,I have same problem ..
