c350e hybrid battery fault
Hi there,
Has anyone had an issue with their plug-in battery not charging the hybrid component of their car? My battery flashes a light displaying battery fault. I can’t find a reference in the manual to troubleshoot this issue.
Thanks in advance.
Thanks in advance.
But what is flashing in your car? Nevertheless, i would contact a service center.
It could be any number of things: it sounds like you need to take the car to a dealer for diagnostics.
Same charge fault!
Hi there,Has anyone had an issue with their plug-in battery not charging the hybrid component of their car? My battery flashes a light displaying battery fault. I can’t find a reference in the manual to troubleshoot this issue.
did you solve the problem with charge fault? I have the same problem for a few days.Last edited by Serj Istrati; 07-03-2019 at 06:32 PM.
I6 and V6 Diesels
Maybe you've already tried this, but just in case this is helpful
I've heard of more than one person with a charging cable fault...try third party charging (chargepoint, etc) or someone elses charging cables and see if that solves the problem.
If you're still under warranty the charger that came with the car is covered.
