Issue with 2019 C300 (door and air pressure problem)
Old Dec 4, 2018 | 12:59 PM
Aidenk's Avatar
C300
Hey guys,
My girfriend got the new 2019 c300 last week but we are having an issue with the car. And I wanted to check with other owners to see if you have the same issue.
Driver side door wouldnt close properly..wouldnt close all the way with normal force . Dealer exchanged to another vehicle. But the new car also has the same problem.
And we later found out its bc of the air pressure of the car. So we tested multiple 2019 models and all of them had the same issue..just with the driver side door..when I leave any windows down or any other doors opened, the driver side door closes properly.
Both my girlfriend and I have been driving Benz for a number of years so it's not something we are being picky on.
Do you have the same problem? Should we notify manufacturer? What do you suggest we do?
Thank you
Old Dec 4, 2018 | 03:32 PM
Simon Guertin's Avatar
2015 c300 4matic with sports package
Maybe the dealer forgot to remove some factory seal on the pressure flap? This pressure flap is pretty standard on all cars. Or maybe the new rear seats are so tightly packaged, that the air does not go through the trunk where the flap is?
Old Dec 4, 2018 | 03:51 PM
Aidenk's Avatar
C300
Hi Simon,
Thank you for the information that you kindly shared. Would you happen to know where in the trunk this located? And is this something I can easily remove without going to the dealer? Thanks
Old Dec 4, 2018 | 04:04 PM
Originally Posted by Aidenk
Hi Simon,
It it should be under the trunk carpet.
see graphic here for location. It’s called the vent valve
Vent Valve - Mercedes-Benz (205-830-12-01)
check that the flap is moving freely.
https://www.mboemparts.com/oem-parts...ItMGwtbDQtZ2Fz
Old Dec 4, 2018 | 05:13 PM
Aidenk's Avatar
C300
Thank very much! I'll take a look and let you know!
