Auto windows roll up and down function
Old Dec 28, 2018 | 01:06 AM
Coetzee's Avatar
C180 W205 Exclusive
Guys,
2015 C180 Exclusive but cannot use the function of having the windows either rolled up or down when pressing the close or open button on the key.
Are these functions available on all W205 models and if affirmative, how do i get mine to do such.
Old Dec 28, 2018 | 01:46 AM
sentralfyr's Avatar
2015 S205 AMG
Try this: Or read more HERE
Resetting the side windows
If a side window can no longer be closed fully, you must reset it.
Close all doors.
Turn the key to position or in the ignition lock.
Pull the corresponding switch on the door control panel until the side window is completely closed more.
Hold the switch for an additional second.
If the side window opens again slightly:
Immediately pull the corresponding switch on the door control panel until the side window is completely closed more.
If the corresponding side window remains closed after the button has been released, the side window has been reset correctly. If this is not the case, repeat the steps above.
Old Dec 28, 2018 | 10:16 AM
Coetzee's Avatar
C180 W205 Exclusive
Thanks for the reply, but i am talking about the option to use the key (open & close) function to either open or close the windows by pointing at the door handle.
My vehicle does not have a auto start function, nor any indication of a receiver on the door handles.
