Apple, Android option how does it work?
Old Jan 31, 2019 | 07:51 PM
xxnonamexx's Avatar
2008 C Class Sport
My '18 C has the Apple, Android multimedia option to use the Nav and google assistant. How does it work? What do I need to do to set it up?
Old Feb 1, 2019 | 12:09 AM
fabbrisd1's Avatar
A gaggle of MB's
1. If Android - download and install Android Auto on your phone 1st - have USB connecting cable for your phone/insert into USB port showing "phones" next to it - plug phone in - start car and start up center stereo/Audio 20 - your Anroid auto should start-up 1st time... follow the prompts on the screen... when in doubt go to mbusa.com website - unders Owners - download pdf Owner's Manual
Old Feb 2, 2019 | 08:26 PM
xxnonamexx's Avatar
2008 C Class Sport
what does stereo/Audio 20 mean? I thought under media?
Old Feb 2, 2019 | 10:08 PM
fabbrisd1's Avatar
A gaggle of MB's
Download your manual - mbusa.com - under owner's section
Old Feb 3, 2019 | 08:08 AM
xxnonamexx's Avatar
2008 C Class Sport
I have the manual in my hand and downloaded. When I search for android nothing comes up. I read about Audio 20 as well as multimedia. I have my phone hooked up via BT works without issues its just unable to get the android maps on the display using Android auto. I have it plugged into the usb icon with a phone image.
Old Feb 3, 2019 | 10:05 AM
jerhu's Avatar
C43, GLS450
You need to select Android Auto from the telephone menu.
Old Feb 3, 2019 | 11:20 AM
xxnonamexx's Avatar
2008 C Class Sport
i will try that. i thought it was media thanks
Old Feb 3, 2019 | 02:33 PM
benzdude's Avatar
Top Answer: 1
2015 C300 4Matic Sport
Note. There are usually two manuals. An owners manual (for the car) and a command manual (for the multimedia system).
https://www.mbusa.com/en/owners/manuals
Old Feb 3, 2019 | 03:01 PM
xxnonamexx's Avatar
2008 C Class Sport
I don't have a command system with nav just auto play. The telephone menu worked to get the Android auto to work. Thanks alot.
Old Feb 3, 2019 | 03:31 PM
benzdude's Avatar
Top Answer: 1
He says only the second USB slot with the phone icon will work.
Old Feb 4, 2019 | 04:16 PM
waylo's Avatar
2018 GLC 300 4MATIC
I have a similar issue in that Android Auto just does not pop up after plugging in my Android phone. I have a 2018 GLC 300.
I know I have smartphone integration because Apple Carplay works just fine.
When I connect my Samsung S9, however, nothing pops up. There is no option seen on the radio menu.
I do have a SD Nav installed. I removed it just to see, but still no Android Auto option. (I do not need to remove the SD Nav for CarPlay to initiate).
Any thoughts?
EDIT: Oh wait, just watched the video in the above posts. Maybe I need to activate it first through the phone menu.
EDIT2: Derp derp, of course that was it. It's different in other manufacturers where you just plug and go.
