c220d stop/start
Old Mar 20, 2019 | 09:52 AM
renonutter's Avatar
w205
c220d stop/start
I have a c220c w205 2016.
The stop start worked fine for the first year, but now the green light does not come on until the car has covered over 70 miles. I have taken it to merc and they say there are no faults.
If I disconnect the battery for an hour, the stop start works fine again for about 3 weeks, then the distance you have to drive before the light goes green gets further and further.
Old Dec 29, 2020 | 09:40 AM
beemer guy's Avatar
640i Gran Coupé
Great thread! I'm currently (as you can probably tell) driving a BMW 5 series, but thinking I might go back to M-B after reading some great reviews on the refreshed E-class. I hate these start/stop systems, and so I found this thread.
Note that the eBay ODBII fix mentioned earlier in the thread clearly states on the auction description that it does not work on 2019+ models. It makes me wonder if this method described by the OP will work on the newer cars (such as the E450 I'm thinking about).
Old Dec 29, 2020 | 12:26 PM
Andy74's Avatar
W205 2015
If your start stoo system stopped working then you are one lucky w205 owner. I wish mine stops 😂
Old Feb 28, 2021 | 07:52 PM
01Rocky's Avatar
GLK 350
I purposely joined so I can thank the OP. It works perfectly. I have a 2014 GLK350. I pulled the plug on the negative terminal as per OP. When I start the car - the ECO light stays on for about a couple of seconds and turns off automatically. You cannot turn it back on (of course). I did not observed an increase idle in neutral (~600rpm) or stopped in gear (~500rpm). I observed for a week with the plug on and with plug off and rpm is the same. Also with the discussions of alleged overcharging the battery - who cares. You are lucky get 4 to 5 years of life on a battery anyways as mine was already replaced.
Note for anyone that is doing it - not to confuse with a similar looking plug on the the positive terminal (not the actual battery terminal) as well. Just follow the OP.
