You can see the differences here, it is possible but in my opinion I wouldn't do it because if the tire width ends up smaller than the wheel it will not only look bad but it gives less protection of the wheel from curb rash . Also will affect performance in some ways due to the tire stretching to fit the wheel, so some shops refuse to install smaller tires that don't "fit properly".
As @BayAreaAMG stated, you will probably need to get front rims for the rear since the width is different. Otherwise 225/40/19 all around would enable you to do a proper tire rotation to get the most wear out of the tire set.
Thank you for the information, it is really helpful.
That answers my question, I just wanted to know if the front and rear rims are the same width, if it is I wanted to put 225s all around, but it seems that they are different, in this case I will just go with the factory original spec.
